Old 01-28-2010, 09:29 PM   #1
tacoboy
tacoboy is an unknown quantity at this point
Stock Pistons: SR20DE vs SR20DET
Hey guys - I need to pick your brain.
I have the option of re-assembling my sr20 with the stock 8.5:1 pistons with new rings, or tossing in a set of 9.5:1 SR20DE pistons with new rings from a FWD sr20 I have in the shop. Are they made of different alloys? Any differences other then having to notch them for the oil squirters?
I really like the idea of a faster spool, and more "get up and go" of the higher compression number.
Thoughts?
tacoboy is offline   Reply With Quote
Old 01-29-2010, 02:12 AM   #2
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
The NA pistons are only 9:1. They are also weaker and you'll have to notch them out for the oil squirters like you mentioned.
HYPNOTIK is offline   Reply With Quote
Old 02-05-2010, 12:00 AM   #3
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
the sr20de pistons are really not meant for turbo applications thats why they made det different ???
jdm213 is offline   Reply With Quote
Old 02-05-2010, 08:28 AM   #4
rubhamusan
rubhamusan is an unknown quantity at this point
The sr20de ring lan grooves are not as thick and the rings are thinner than det's by a goodbit
rubhamusan is offline   Reply With Quote
