Old 10-05-2002, 11:47 PM   #1
luke91
luke91 is an unknown quantity at this point
Are the timing chains the same between the US spec SR20DE's, and the SR20DET?
How about water pump and oil pump gears?
I know a few shops online sell them, but they are too expensive.  Any ideas?  I don't want to get stuck paying $250 for a damn water pump!
--luke
'91 fastback.  '97 S13 blktop SR20DET.  Cstm Frnt Mnt IC w/ cstm 2 1/2" piping.  stnls stl fltr.  3" cstm DP & exhst w/N1 muff.  Walbro FP.  ACT 6 pck cltch.  Go Fast Bits crnk plly.  Ground Control coils.  KYB AGX shks.  [email protected] w/g-tech pro.  17psi.  All work and fabrication done by ME
luke91 is offline   Reply With Quote
Old 10-06-2002, 12:31 AM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
SRSwap.com and heavythrottle.com have SR motor interchange lists.  I know heavythrottle's in in their FAQ section... and I know SRswap.com has it on there, but I can't tell you exactly where offhand.
Hope that helps!
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 10-06-2002, 12:43 AM   #3
luke91
Well, both  those shops sell the parts I need specifically for the SR20DET, so I'm guessing there's no parts interchange.  I just wanted to see if anyone has any first hand experience.
Thanks, though.
--luke
Old 10-01-2013, 01:30 PM   #4
Diehardsr20
Diehardsr20 is an unknown quantity at this point
Just thought I'd throw this in there. Pulled a Coolant Temp Sensor (and connector pigtails) from a 02 xterra with a vg33de for laughs. It bolts right in and sends the same signal as the z32 and ka24de cts. I Dont have the part number however.
Diehardsr20 is offline   Reply With Quote
Old 10-01-2013, 01:44 PM   #5
DJ 21o3
DJ 21o3 is an unknown quantity at this point
holy bump, look at the date man.
DJ 21o3 is offline   Reply With Quote
