Old 04-30-2013, 12:51 AM   #1
SnaggleToof
SnaggleToof is an unknown quantity at this point
circuit sports seat rail problems
I thought these rails were supposed to be good... and super low. got mine in the mail today, and it doesnt even come close to fitting my 1995 240sx, and they seem to be pretty high... tons of room to go lower.
doesnt even come close to the hole...
crazy angle
SnaggleToof is offline   Reply With Quote
Old 05-01-2013, 07:48 PM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Did they send the wrong ones? S13 or something mayb i dunno
Also the first pic looks like you have the slider handle from the passenger side...
Only one should have a handle AMIRITE?
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 05-02-2013, 09:45 AM   #3
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
I have the same rails, once you actually tighten them down it will suck the back mounting bolt hole on the outter rail basically where it needs to be. The inner rail bolted up for me no problem.
Its definitely tight, but it will work pending on what seat you use.
Also they room under the rails will be there because the bucket seat will drop lower once you put the brackets on the side, and the bottom of the seat will sit lower than the rails themselves.
I have it installed in my car with a Recaro Pole Position and the seating position is pretty low.
Sales @ Enjuku
email:[email protected] phone:352-241-8399
Prok0 is offline   Reply With Quote
Old 05-28-2013, 08:09 PM   #4
SnaggleToof
So i had to bend the left side rail to make it work, put my bride vios low max seat in and my head is almost touching the roof (with no roof liner too)
Sold the bride and bought a sparco sprint, same problem. Therr is at least 3-4 i ches between the bottom of the seat and the floor... Probably going to toss this rail in the garbage and make my own.
