Old 01-17-2017, 09:12 AM   #1
Mintvert
Mintvert is an unknown quantity at this point
Weird backup light issue
So I'm trying to cross all my T's and dot all my I's before I start my 5 speed swap on my vert.
To begin with, none of the switches on the 5 speed worked. Since I'll need the neutral and backup light switches, I ordered replacements. The new neutral switch works perfectly but the new backup light switch doesn't.
If I pull the switch out and push the button in by hand, it makes a connection but it seems like the switch is too short to reach the shift rod when its installed.
Do I have some weird transmission or something? Any suggestions would be helpful!
The new backup light switch I ordered was an Airtex 1S5835
Last edited by Mintvert; 01-17-2017 at 09:14 AM.. Reason: adding part number for b/u switch
Mintvert is offline   Reply With Quote
Old 04-03-2017, 09:21 AM   #2
panmanstan
panmanstan's Avatar
panmanstan is an unknown quantity at this point
Is it a KA trans? Go into autozone/advance/ect. and ask for a reverse/neutral safety switch and that should be it. Ill get the part number on my box tonight for you. If not your trans has something wrong.
panmanstan is online now   Reply With Quote
