South Western States Arizona, California, Hawaii, and Nevada. |
08-07-2011, 02:50 PM | #1 |
Trader Rating: (50)
Feedback Score: 50 reviews
need local oc cali help sr experts or so
Ok just got this car in a trade it has a red top sr but has a bad idle n need help eliminating possibilities or pin piont the problem I want to ride it already so from a fellow 240 owner to another I needs ur help plz n thanks
....that what she said |
08-08-2011, 06:10 PM | #5 |
There are way to many factors that can contribute to poor idle qulity to diagnose over the internet.
But heres a suggestion remove & clean the IAC assm. Also check for vaccume leaks,Or vacume hoses done wrong. This is just a start!!!!
MR JACKSON. |
08-11-2011, 09:18 PM | #11 |
Yo if you still have issues,PM me your adress & I may be able to come over & check it out. Or if its drivable you can bring it by ,Im in the city of Orange. LMK
MR JACKSON. |
08-12-2011, 08:15 AM | #12 | |
Trader Rating: (50)
Tried the idle srew n nothing also u got pm sir
08-12-2011, 11:12 AM | #13 |
The tps could be off too, I would check the ecu for codes. Even if u don't see any on the dash it could mean it wasn't wired in. Check the tps voltage, check the timing, compression test. Did he change the fuel pump or is it still a stock KA? hope he did if not he might have been boosting high on a stock pump and run the motor lean killing the rings on the pistons.
95 240sx RB20 415whp 91 Nx2000 VVL yo |
08-12-2011, 01:35 PM | #14 | |
Trader Rating: (50)
09-07-2011, 01:06 PM | #16 | |
Garage BOSO
-Garage BOSO- -Racetune Engineering- |
09-07-2011, 09:26 PM | #17 |
if you want professional help. Koji knows his way around a SR. and its close to you.
DRIFTSPEED Address 11082 Winners Cir., #B Los Alamitos CA 90720 Tel 562-342-9000 Fax 562-342-9002 Email [email protected] Business Hours Monday - Friday 10:00 am - 7:00 pm PST
09-08-2011, 12:51 AM | #18 |
Trader Rating: (30)
Feedback Score: 30 reviews
Try the simple things first, like mentioned before, clean IAC, and clean the MAF. Any exhaust leaks? Does pumping the brake pedal make it die/bog down?
09-14-2011, 03:19 PM | #19 |
Garage BOSO
115 E. Gardena Blvd. Suite #3 Gardena California 90248 (310) 715-1380 SR20DET Experts.
