Old 07-06-2014, 10:48 AM   #1
Powell
Powell is an unknown quantity at this point
Ignition trubbelshooting ca18det
(Don't know if it's in the right topic)
Hej guys! Bought a Nissan 200sx a while back with a bad engine, when I bought it the engine was out of the car but anyways, I restored the engine and out it back in and wired everything up. Try to start it and it won't fire, :/ I checked with fuel and it was good but there was no spark. Don't really know what the problem is. Any of you guys that have some tips? Or anyone that have had the same problem?
Powell is offline   Reply With Quote
Old 07-06-2014, 11:42 AM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
What do ca use to fire the spark plugs ? Cas? Since you got the engine out of the car who knows what condition the sensors/harness is. Just be patient and search for how to test the ignition system.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 07-06-2014, 12:44 PM   #3
Powell
Yeah, it uses cas. I will try see if the ecu is in prop.er condition too
Old 07-09-2014, 01:12 PM   #4
Powell
Found the prob, the nistune in the ecu was not installed properly :P
