For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Everything has about 1k miles on it... like NEW.
Need this car gone, buy now for $2800, top her off and get drifting 2010 style! Chassis Neukin Tig Welded Roll cage chassis with ARP studs and 5lug new rotors and hwak pads 1.75 DOM tube .120 THE SAFEST out there Custom cut gussets on drivers side tie cage into chassis for a ridged setup. -Padding for impact safety and if you drive on street with no helmet Muteki blk open wheel lugs and key Walbro 255 intake fuel pump hood with louver for vmount Key for both doors, not used for start tho.. just switches for start lock bolt in wheel is illegal for TTU race classClear title and steetable Odyssey PC680 battery (11 pounds!) 6 switch bank (used right now: fuel pump, fan 1, fan 2) Two main switch near cluster (ign, and start) Was a automatic so the chassis was setup and 5speed setup installed with correct pedals ect so you cant really tell but thought id toss that outthere. THE LACK OF RUST IS GREAT, was not fixed.. it really has no major rust on chassis or frame rails.Has some small dents and such, i was never worried about looks since its a racecar. Would be easy to clean her up and put a kit or paint on.New slave and master for the clutch, new hardline and stainless flex line. stock springs and shocks -Megan Front Roll Center Adjuster ball joints $100 (after you lower car these help flatten the lower control arms so Nissan designed suspension goes closer to intended geometry) -Megan front steering S13 Rack Ends add more steering angle -Megan Tie Rod End -Megan Front Pillow Tension Rods -Megan Rear Lower Toe Arms -Megan Rear Lower Traction Rods -Megan Rear Upper Control Arms Russell stainless brake lines Neukin welded diff in pumpkin with blasted cover and black painted bolts Steel one piece drive shaft was like $200 removes rotational weight and sends power to rear wheels for a clean snappy feel. ready for s13 obd2 96 higher power S14 motor/ecu/trans has the ecu you can put Nistune on for a fully programable chip which id highly recommend to get this car to the next stage Custom Wire harness from Nissan Wire Specialist and low miles clutch from center force Brand new alternator Neukin stainless Oil feed and stainless oil drain for turbo lube and cool system Had the Neukin vmount setup, but its not turbo now, just a stock radiator and cold air intake, has metal bracket and hood for vmount. 3" exhaust for turbo. -Stock hood lightened and louvered perfect for the intercooler core. -Sparco hood pins/latch system from Italy 3" stainless exhaust system Neukin Mid Pipe Vband inlet and outlet with clamps or 3" aluminum race exhaust downpipe back with custom mounts and hangers saves 20lbs and sounds good NRG short hub, quick release wheel 2.5 and "Race" leather wheel w red stitch One set of SportMax 17x8 with pretty much brand new fuzion zRi for daily or running to a event brand new (great in the rear for drifting) 4) 10mm aluminum wheel spacers on the 4 corners for better wheel spacing. S14 cluster and two of the needed three plugs $80
Neukin Motor Development llc 399 River Bend CT Fort Wayne IN 46803 -->Neukin Store<-- -->DRIFT Clutch Store<-- Last edited by neukin; 02-04-2010 at 10:10 AM.. |
ummm here are a few at two angles the bottom one is the kit you would get.
Neukin Motor Development llc 399 River Bend CT Fort Wayne IN 46803 -->Neukin Store<-- -->DRIFT Clutch Store<-- |
Ya the hood latch support needs cut, its well worth it. You can always get another one and put it back to stock later. Its a few spot rivits and you can get that section of meny junk s13ers. Id just do it.. for super sexy vmount action you must get nasty with a cut off wheel.
Just the motor, um not sure like $450, it has topfeed injectors and rail on it for easy tuning and injector choices. Rail has a gauge on it too. Runs great vac, no smoke adn it runs and starts like a F-ing champ. That way i can sell the trans for $400 with the newish centerforce clutch. Im sure shipping would be about $130 to massachusetts on pallet. Few things sold and i didnt update list.
coilovers pending for sale fri/sat.... we will see.
still have the kaaz 2WAY!!! shoot a price 700 installed in there ready to rock with low miles and 3 fluid changes already with kaaz fluid. best condition used kaaz evvva
Thanks, coilovers sold. Need this KAAZ sold, someone pick this up its a deal!! 2 way super low use and fresh fluid. Installed in pumpkin already. 700 plus ship
![]() Join Date: Jun 2007
this isn't an old thread, there has been discussion in it recently
How much for the steering wheel setup shipped?
"I'm a rage-aholic, I just can't live with rage-ahol!!!" |
Have this KAAZ out and ready to sell with final drive gear on it still all locktight'd n tq to spec ready to drop in....
(Can do Close to $700 shipped for most 48state guys west coast add $15) 2-WAY two way... very low use, two kaaz gear oil changes already three if you count the shit gear break in fluid it first had for break in. lmk need this gone!
#17 |
Still have this car but not turbo/vmounted and no coilover, welded diff no kaaz want $2800 for it now
Tags |
coilovers, kaaz, neukin, s13, s14 |
