Need Help with Consult-II
Since this engine (1998 SR) is in a 240Z I dont have the dash harness, I NEED to pull codes. Looking at the ECU pin outs there seem to be 3 pins for Consult-II. Shouldnt there be more? Also, any ODB2 scanner will pull these codes right? Need the codes, need'em. Thanks
1971 240Z SR20det. 1989 300ZX VG30ET |
![]() Join Date: Dec 2002
Three wires for data, a ground, and ignition. Five total.
http://www.tangentrix.com/forums/vie...hlight=consult hopefully this helps out a bit...I am not sure that it has the information your looking for... but if you ask the guys on that forum they will be able to help you out for sure.
R240NA, What do you mean by Ignition? Tach signal? and this will work with any ODB2 scanner right? Now i just need to know the orders of the wires in the clip that plugs into the scanner. Thanks guys!
G2ic02, Yes that link looked pretty good, like what i'm going to have to do, make a plug for a scanner. I have a laptop aswell so lets see where i get with this.. Thanks
Check this man, this is sick, leave it to the aussies to make a consult protocal reading black box that you can read on your laptop, oh and it can data log and realtime display every sensor in your car aswell. $115US I'm allready on the list for one.
http://www.plmsdevelopments.com/consult_if.shtml
![]() Join Date: Apr 2004
I have the PLMS software on my DIY Consult interface. Its pretty neat, about $35 built and $30 for the software. I just wish the gauges could be customized with DataScan. The data logging is ok with excel but Martin Cooksey's Datalog Viewer is much better for reading what was logged. http://www.blazt.biz/300/interface/dviewer.htm
A working map trace would be awesome too. |
