60mm Extended Studs, Spacer & Coilover question
I am running Kei Office coilovers, 60mm studs, and a 17mm spacer in the front of my s14. The wheels are 18x10+36 (effectively 18x10 +19). tires are 235/40 Federal 595's. I AM BUYING NEW COILOVERS SOON. I want to find one with better clearance than the Kei Office.
Here's what it looks like inside.... It's fine now, but i want to go lower. ![]() ![]() Here are my questions: 1. Is there a coilover besides Megan (and their extended bracket) that offers better clearance than these Kei Office? 2. How big of slip on spacers can i run with 60 mm studs? (currently at 17mm spacer)
![]() Ls460, 240sx, Super Avenger, Chronofighter, Navitimer |
I dont think different coilovers are going to really give you that much more clearance .maybe the megans will. I have an18x10 +9 in the front with gold tein coilovers and I just run a small tire and the inner lip rides in between the coils of the spring . Why are you getting new coilovers ? Just for clearance issues?
Ever seen 25mm slip Ons with 60mm studs. Is that safe?
![]() Ls460, 240sx, Super Avenger, Chronofighter, Navitimer Last edited by Breitling; 06-24-2012 at 08:03 PM.. |
Kill the spam!!! ^^^
Answer my questions please!! Here are my questions: 1. Is there a coilover besides Megan (and their extended bracket) that offers better clearance than these Kei Office? 2. How big of slip on spacers can i run with 60 mm studs? (currently at 17mm spacer) Can i go 25mm?
Kill the spam!!! ^^^ x2
![]() Join Date: Oct 2004
1. I think Power by Max (Part shop max) might have an extended base.... But I think that might be the only company... I would check their coilover review which I think you can find here on the sight.
2. Seriously, 25mm is pretty dangerous man.... get some real wheels with better offsets. I would get some ARP studs.... 25 ish pushing it though on a 60mm....
+1 for pbm coils, i do believe they have extended brackets....
+1 for better wheel offsets, im running an 18x12 +20 with a 335 rear tire, and an 18x10 +10 with a 265 front tire, and i have decent clearance |
#10 | |
Thanks for the insight about PBM. I do have real wheels (3piece and all). Is 25mm dangerous because of the lack of threads for the lug nuts to grab on to? Or is it dangerous because of the extra stress it would put on the geometry?
#11 | |
Right now my 18x10 +19 clears in the front with my Kei Office.... but if i lower it more the springs will hit the tire. (see pic above). what's this i hear about loosening the coilover-to-knuckle bolts and pulling the whole thing outwards while someone else tightens the bolts back up? Has anyone tried this? what were your experiences?
#12 | |
yes but in most cases this is for people who have slotted coilover bases or modified theirs to be slotted. it is usually used as an attempt for more camber.... |
Man w/ CTSV & a Car Seat
I posted up on the wheel fitment thread but I'm running 2 10mm spacers on mine. Can maybe add another 3mm tops but your lugs would barely be threaded into the studs. My mutekis are almost threaded all the way in minus 2-3 threads.
#14 | |
Pulling it out.... I don't think any bolt with that amount of force exerted on the wheel can stay there for long.... Don't bother... both problems.... For street rolling, 20mm spacers, is probably OK..... Do any tracking and would never go over 10-12 is the general consensus.... Just a lot of force on the stud especially without hubcentric lips on them (HR Spacers). Also it will be close to short and you asking for it lol.... no having enough thread lol....
#16 | |
Also, for now... we know that MEgan and PBM make extended brackets. anyone else? anyone ever make/mod their own? Lastly, my wheels are 3 piece and i can buy new inner barrels for the front. Shoudl i back it of .5 inch or a full inch?
#17 |
Just called PBM in Cali... talked to a guy named Nate. He said that they dont offer an extended bracket.
Anyone?
#18 | |
#22 |
Seriously. I think you are going to need a skinnier wheel with a higher offset. do you REALLY need a 10in wide wheel on the front?! you are only running a 235/40 anyway. You said your wheels are 3 piece. get some new barrels to get a skinnier wheel and lower offset. Or you could put some s14 LCA on and effectively move your wheel out 15mm...
#23 | |
Please explicate on this
#24 |
S14 LCA's are just a tad bit longer than S13 LCA's... is what he means..... All else I think the sway bar should fit and the tension rods must be extended a little more to fit the S14 LCA.
#25 |
![]() Join Date: Apr 2010
Trader Rating: (38)
Find out what the ID is for the megan extended brackets & see if the coils you are getting have the same ID.
EDIT: nvm, found that they will not work for any other company. Disregard my post. |
#26 | |
my car is an s14....
#27 |
![]() Join Date: Nov 2007
Buy PBMs cause they are sweet.
Get lips re-done. Go less of an offset with same wheel. running 10's. Go with something like a +10 offset. It will move the wheel away from the coilover. Spacers do exactly what lower offset wheels do...they move the wheel farther away from the coil. You are trying to do too much, and it's really simple. |
#28 |
Well, i am considering PBM, my goal is to be at or under 1K shipped for coilovers. Suggestions? I have heard good things about Fortune, PBM, and Stance.
#29 | |
Trader Rating: (38)
Fortune, PBM, Stance > 1,000 budget. |
