Old 01-29-2016, 02:40 PM   #301
drewr4411
drewr4411's Avatar
drewr4411 is an unknown quantity at this point
Originally Posted by Ronald_Mcdonald View Post
Just looks like some custom bent, tucked brake lines. As long as it goes to the flexible lines in the wheel wells, with no kinks, that's all that matters.
Right but the cylinder looks to only have one inlet? how do the other two get implemented in?
89 S13/2JZ Silvia(Project Phoenix)
IG @awrperformance FB awrperformance
drewr4411 is offline   Reply With Quote
Old 01-29-2016, 03:05 PM   #302
TheRealSy90
TheRealSy90's Avatar
It runs down by the front left wheel, T's off to that brake line and another line that runs to the front right wheel, then T's off again to that brake line and the Prop valve that attaches to the oem hard line which runs to the back brakes.
Such a good signature.
Old 01-30-2016, 11:18 AM   #303
lilcim
lilcim is an unknown quantity at this point
Couldn't explained it that well! Exactly. Splits with T in the end up to the OEM all the way back.
Simplified to the most easy road, and everything works fine. Bleeded everything and no leaks anywhere. Sure thing, with the ChaseBays/Wilwood brake booster eliminator and the Z32 upgrade, the pedal is way harder.
IG: @cimonbrouillette
www.LowLevelStore.com
lilcim is offline   Reply With Quote
Old 01-30-2016, 11:21 AM   #304
lilcim
Back from the machine shop. Excited on how good it ended up!
1-day job, only 70$. Now, only have to match it with the powder coated intake, and give a little personal touch to replace the TRC sticker.
It is really evident that the engine is almost ready to start! Finalizing the last parts to buy:
NGK Sparkplugs
Manifold Bolts
Vacuum lines
Heather hoses
1-0 Gage for Battery Relocation
Going to a local drivetrain shop this week to do the custom driveshaft!
Old 01-31-2016, 12:16 AM   #305
DriftingBrandon
DriftingBrandon's Avatar
O_O Should of went through with my s13 build... Abs jelly man! VS-KF that b
Old 01-31-2016, 08:14 PM   #306
Jcuban1s13
Jcuban1s13 is an unknown quantity at this point
Coming along just perfect!!
Jcuban1s13 is offline   Reply With Quote
Old 01-31-2016, 08:57 PM   #307
lilcim
Received my Oil Cooler kit, and my TurboSmart 38mm Wastegate also.
Let's kick the week off!
Old 01-31-2016, 08:58 PM   #308
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
this is such an awesome build! i love your custom front fenders too!
Old 02-01-2016, 11:24 PM   #309
lilcim
AMAZING NIGHT & UPDATE. FIRST START! Wow.
Braided lines received from our local shops, looks so good. So exciting to get all those final parts and bolt things up knowing you won't go back!
The Z32 upgrade. Wow.
And finally... the FIRST START! Sounds so MEAN.
So much stuff left to do, but that's something REALLY motivating right now. Gives us the energy for the last stretch!
http://vid254.photobucket.com/albums...pswu2ubybe.mp4
Old 02-01-2016, 11:42 PM   #310
2F0-T
2F0-T's Avatar
2F0-T is an unknown quantity at this point
Oh me oh my. I like the quality in this build
Sent from my SAMSUNG-SM-G870A using Tapatalk
2F0-T is offline   Reply With Quote
Old 02-02-2016, 06:44 AM   #311
forgotten
forgotten's Avatar
forgotten is an unknown quantity at this point
God the engine looks so SEXXXX
forgotten is offline   Reply With Quote
Old 02-03-2016, 09:15 AM   #312
drewr4411
drewr4411's Avatar
can you post more pics of how you cut your front rad support?
Old 02-03-2016, 11:21 AM   #313
ehhhregartless
I remember that feeling. Awesome ride!
www.zeedakay.com
IG: @zeedakay
Old 02-03-2016, 08:58 PM   #314
lilcim
Another productive day! Bought some sanitary stainless steel to do the custom exhaust and also for the FMIC piping.
Next step is to find what catback/muffler I'll put with the 2J. No way I'm leaving this straight lol!
Also sold my PBM Coilovers, finally! My new SCALE Innovative Series are in production right now, pumped to get them! Still doing the Swift springs upgrade.
And finally, oil cooler is dialled in! Too bad it will be hidden behind the huge FMIC.
Old 02-03-2016, 10:45 PM   #315
forgotten
forgotten's Avatar
LWLVL (L) my *SNIP*
Last edited by FaLKoN240; 02-12-2016 at 09:28 AM.. Reason: Don't use racial slurs around here
Old 02-04-2016, 12:27 PM   #316
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
Please do straight pipe. You'll be aight.
Ramonesfreak2010 is offline   Reply With Quote
Old 02-05-2016, 10:08 AM   #317
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
Do you have any experience with the scale coilovers? Or will this be your first go with them?
Their payment plans have caught my attention.
Javi802 is offline   Reply With Quote
Old 02-05-2016, 10:21 AM   #318
lilcim
I work for Scale. I also own one on my daily VW CC and loves them.
Old 02-05-2016, 03:52 PM   #319
lilcim
FINALLY THERE! DriftMotion Pulley Kit! Will be able to install the belt, and finally set all the radiator and coolants!
Old 02-08-2016, 09:15 PM   #320
lilcim
Got the DriveShaft! So amazed.
That's when you see this, you know you've went to the right place. Old local shops who've done this forever, knows about his work.
Aluminium tube, all balanced and painted for only 200$CAD (140$USD), in less than 2 days.
Fits right in there, like a glove.
Received also my exhaust wrap for the downpipe part. Welded also the O2 sensor on it
DriftMotion pulley kit all set, with the belt.
NOW TIME TO REFRESH the baby. Radiator time!
Took a vid on how close it is, haha! Chopped the pulley studs and the shaft also a tinyyyyy bit.
And oh. Goodnight
Old 02-09-2016, 04:27 AM   #321
lgsr20swap
lgsr20swap's Avatar
lgsr20swap is an unknown quantity at this point
Wow so close already!!!!
Sent from my SM-N915V using Tapatalk
lgsr20swap is offline   Reply With Quote
Old 02-09-2016, 12:32 PM   #322
backfast
backfast is an unknown quantity at this point
I'm sure you hear this time and time again but, this build is so dope.
backfast is offline   Reply With Quote
Old 02-09-2016, 06:20 PM   #323
lilcim
Thank you so much! Appreciate it
Old 02-09-2016, 06:52 PM   #324
mhubeny180sx
mhubeny180sx is an unknown quantity at this point
Originally Posted by lilcim View Post
nice build, whats with the dash tho? did you spray it with bed liner? or just the picture is making it look weird?
mhubeny180sx is offline   Reply With Quote
Old 02-09-2016, 07:21 PM   #325
lilcim
Only dust lol the complete car is in need of a CRAZY clean up in&out.
Old 02-10-2016, 09:33 PM   #326
lilcim
New WS dialed in! Woa. CLEAR VISION now.
The 27-year old WS was all sandblasted and couple of stone chips with the year.
Hello.
Old 02-12-2016, 05:14 PM   #327
lilcim
Received both gauges in less than 1 day from Amazon! Amazing transaction.
Innovate Motorsports Wideband (Air Fuel Ratio)
Innovate Motorsports Oil Pressure & Temperature
Now waiting for Street Faction to do their magic with the pods. To be continued..
Old 02-13-2016, 08:01 PM   #328
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
Best gauges ever. I've had wideband for 4 years still perfect and got pretty much all the other ones as well. You won't regret them
mr.nismo. is offline   Reply With Quote
Old 02-14-2016, 06:54 AM   #329
lilcim
@dev71893 Thanks sir! Always loved, nice to hear that I've made a good choice.
Also received my Power Steering Reservoir from ChaseBays! Awesome quality as usual. Will fit perfectly in the bay, sleeper and that's what I was looking for.
http://www.chasebays.com/chase-bays-...ing-reservoir/
Old 02-15-2016, 10:15 AM   #330
tuzzio
tuzzio's Avatar
thread is awesome
photos are awesome
quality of work is awesome
price shipped on female to 01077?
s13 180sx 240sx hb
