Old 04-14-2008, 08:11 PM   #1
corey240
corey240's Avatar
corey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymore
Send a message via AIM to corey240 Send a message via MSN to corey240
SR striped a head stud (sr)
i dont know what to do now. i striped it and its bad like it kinda catches but then slides i guess it was half striped befor hand because it was a loose fit but the rest were fine. whtat can i do to get this out?
Email: [email protected]
corey240 is offline   Reply With Quote
Old 04-18-2008, 06:42 AM   #2
verge513
verge513 is making a name for him/her selfverge513 is making a name for him/her self
allen wrech right? got the right size? be sure to use metric bc there so close in sizes, one bolt can be off by a nanometer and wouldnt work right..as far as getting it out if it is the bolt being striped gt a left handed drill bit get it to bite th end of the bolt and as its spining (slowly) pull up with the drill (note left handed drill bit should turn left to drill in)
verge513 is offline   Reply With Quote
Old 04-18-2008, 12:49 PM   #3
corey240
corey240's Avatar
its the right size but im pretty shore it was atleasty half striped if not full striped befor i started on it and its still totaly torqued down so i dono if a drill will help any
Old 04-18-2008, 01:07 PM   #4
karmakaze
karmakaze has a little shameless behavior in the past
you could try to hammer in the next size up wrench or wrap the tip in electrical tape.
if neither of those work, you could JB weld another bolt to the top of it and use it to remove it or go get a set of easy outs from a hardware store.
karmakaze is offline   Reply With Quote
Old 04-18-2008, 02:45 PM   #5
verge513
hes saying the bolt is stripped not the head...still try the left handed bit..if its striped and tourqued then it should pull its self easyer
Old 04-24-2008, 08:09 PM   #6
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
weld something like a t handle to it and crank it out ?
TougeLabs is offline   Reply With Quote
