Old 01-04-2009, 06:44 PM   #1
eazye2000
eazye2000's Avatar
eazye2000 is an unknown quantity at this point
Send a message via AIM to eazye2000 Send a message via MSN to eazye2000
Parts for Sale
Contact Info:
AIM- EazyE4you
MSN- e_appie(at)hotmail.com
Some stuff I have kicking around the house that I'm finally willing to part with for the right price. The S14 still isn't sold, so I'm kind of weary about putting this stuff out there. But she's on craigslist, and local forums.
S14 SE wheels. Standard 5-lug, 5 star pattern.
I have eight (8) total. Four (4) are just wheels. The other four (4) have Falken Azenis' mounted to them. 215/45/16. Still in good shape.
85 bucks for a set (4).
135 bucks for a set (4) with the tires.
S14 SE 5-Lug Hubs.
Stock S14 hubs front and rear. One rear hub had a ding in the grease seal. I took it out, was going to straighten it out, and never put it back in. I can/will do this before they leave. Metal has ding, not rubber.
200 bucks for all four (4)
S14 SE Rear Sway Bar.
Plain as it is. Would like to keep and let it go with the car for some brownie points, but if you need it, let me know.
35 bucks O.B.R.O.
Z32 30mm Aluminum Brakes.
All four (4) corners. Have been bead blasted to bare metal, and painted black with caliper paint. The 'Nissan' has been polished. They are loaded with semi-metalic pads front and rear. I have ft/rr rotors too.
300 bucks for all four (4)
Z32-to-240sx Brake Conversion Lines.
Stainless braided lines to allow installation of Z32 brakes on either model 240sx.
90 bucks for all four (4)
******SOLD******
Z32 Rear Aluminum Knuckle/Uprights/E-Brake.
******SOLD******
5-Speed Swap Stuff.
Manual Transmission, Flywheel, Stock Used Clutch/PP, Crossmember, Bolts for Flywheel/Pressure Plate/Crossmember, Clutch/Brake/Gas Pedals(S14), Clutch Master and Slave.
Cant find line from master to slave. 1-piece stainless braided can be had for $40 online.
300 bucks for everything.
RHD JDM S14 Brake Master.
Line outlets are on 'driver side' as opposed to 'passenger side'.
35 bucks.
Electric Altima Fans
Not sure what year. Dual Electric radiator fans. I pulled them a while back at the junk yard. Looks like they bolt onto a stock 240sx radiator, thats why I got it.
45 bucks
****Adding Parts****
SR Ignitor Chip gimmick
Has pigtails on both sides.
45 bucks
S13 Hood
Pretty mint. Fresh Black paint.
35 bucks
*****SOLD*****
S14 RUCA's
*****SOLD*****
370cc Side Feed Injectors (x4)
Fits KA24DE, VQ45DE, SR20DET. Plugs in directly to stock harness
50 bucks
If you want more than one 'package', let me know. There might be some negotiating I'm willing to do.
Ok, here's some pics for you people.
Z32 30mm Aluminum Front and rears
S14 5-lug hubs. I have front spindles from S14 too.
370cc High Impedance Side Feed injectors with SR20 Ignitor
Z31 Turbo
SR Dump/Elbow, Downpipe, and Cat Delete Resonator
Altima Electric Fans
5-Speed KA Tranny
Some of the parts to go with Tranny. (clutch pedals and parts behind calipers in pics up top)
S14 SE bare wheels. (others outside stacked)
Random stuff. S14 SE Sway bar in there with stock S13 Rear.
S14 Rear Upper Control Arms
eazye2000 is offline   Reply With Quote
Old 01-04-2009, 07:17 PM   #2
chvybeatsford
chvybeatsford is an unknown quantity at this point
Injectors fit stock Red top? If so how many miles on them.
chvybeatsford is offline   Reply With Quote
Old 01-04-2009, 07:21 PM   #3
eazye2000
eazye2000's Avatar
90k'something miles. Clips are stock for SR's and KA-DE. Side Feed, and High Impedance. Plug and Play for SR's.
Same for the ignitor. Pulled the injectors and ignitors out of a Q45 that was 'totaled'.
Sold one set of injectors and other ignitor and guys happy with them. Need O-rings for sure.
Old 01-04-2009, 07:21 PM   #4
chvybeatsford
What i mean is will they work with stock tune,?
Old 01-04-2009, 07:32 PM   #5
chvybeatsford
I have brand new Stock sr20det inj orings that should work with them so rings arent any problem. The set i bought last night ended up with one being stuck open. Not good as far as the reason i needed to even buy them is cause mine stuck open too.
Old 01-04-2009, 09:10 PM   #6
eazye2000
eazye2000's Avatar
Yes they will work with the stock tune. If you had a set with one stuck open, and you bought another set with one stuck open, you should theoretically have 2 good spare injectors left.
Are you positively sure that your injector drivers in your ECU haven't went crazy and fried? Have you tried another ECU? I would hate to sell you something that you don't really need.
Old 01-04-2009, 09:33 PM   #7
chvybeatsford
No had troubles with 3 of mine. The one stuck open and the others firing bad. So i now have a mismatched set. 1 of mine which went through alot of trash from previous owner not changing the complete gas tank after it had filled with rust, lazy person that shouldnt have done the Swap. As far as it being the Ecu it happend on Diff inj #. Fisrt was cyl 2 then cyl 4. the rail i picked up last night had a red inj that he said was 300zx TT. I didnt car cause at the time i really needed only one.
But yes i do need 4 and sure its not ecu realated. Srry was jus ranting a lil.
BTW: i got half my money back since 2 were bad so im not mad at him jus my car.
Jus confirming it is 4 total with plugs?
Old 01-04-2009, 09:51 PM   #8
chvybeatsford
PM sent ...
Old 01-05-2009, 05:46 AM   #9
eazye2000
eazye2000's Avatar
Yep, 4 total injectors with plugs. The plugs are for someone with an application other than a KA-DE or SR. These injectors plug right into a twin cam KA, or an SR factory plug perfectly. I just snagged the clips because I could.
Old 01-05-2009, 06:15 AM   #10
ctsedan
ctsedan is an unknown quantity at this point
What brand RUCAs?
ctsedan is offline   Reply With Quote
Old 01-05-2009, 10:23 PM   #11
eazye2000
eazye2000's Avatar
Originally Posted by ctsedan View Post
What brand RUCAs?
No idea. Got them on eBay a while back.
Old 01-05-2009, 11:37 PM   #12
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Willing to sell/ship just the rear 5 lug to Canada?
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 01-08-2009, 07:29 PM   #13
eazye2000
eazye2000's Avatar
Bumping this post one last time. Hopefully some searching can/will find it.
Updated first post a bit. 5-speed, and calipers/lines are pending.
Old 01-08-2009, 07:31 PM   #14
barshini
barshini's Avatar
barshini is an unknown quantity at this point
i am very interested in the black hood...will you ship to california?
barshini is offline   Reply With Quote
Old 01-10-2009, 12:10 PM   #15
hpipro4
hpipro4's Avatar
Trader Rating: (71)
hpipro4 is an unknown quantity at this point
Feedback Score: 71 reviews
nvm....ss lines are pending...i didnt see!!!woops
hpipro4 is offline   Reply With Quote
Old 01-10-2009, 01:05 PM   #16
dt-p88
dt-p88 is an unknown quantity at this point
5 lug hubs still available?? would you ship if so?
dt-p88 is offline   Reply With Quote
Old 01-11-2009, 12:08 AM   #17
aardvark
aardvark is an unknown quantity at this point
those look like r32 calipers, no z32.
aardvark is offline   Reply With Quote
Old 01-12-2009, 07:05 PM   #18
eazye2000
eazye2000's Avatar
They are(were), indeed, Z32 calipers.
Calipers and Stainless Lines SOLD.
First thread updated.
Old 01-14-2009, 10:08 AM   #19
shadowsc
shadowsc is an unknown quantity at this point
part out 5 spd?
i just need the flywheel?? price shipped to 32779?
*93 S13 Silvia Vert - Ocean Drive Inspired
*00 SC300 - DD
shadowsc is offline   Reply With Quote
Old 01-15-2009, 10:38 PM   #20
OddyseusDSM
OddyseusDSM is an unknown quantity at this point
Im interested in the sways, I specifically have an S14 which should be the bigger of the two....unless thats an S13 HICAS.....in which case i'd ask the dimensions and be interested if that would fit on a s14. $25 picked up? possibly sunday if my deal with an engine goes through, if thats good with you.
might pick up a set of wheels while im there if you still got em
OddyseusDSM is offline   Reply With Quote
