Old 08-26-2008, 04:58 PM   #1
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
Arrow Reving issue after five speed swap from HELL...
Im having a reving problem after my five speed swap.
My car limits me under 4k. It cuts the fuel and bogs down. I think it might be related to this posting( http://zilvia.net/f/tech-talk/174903...st-5k-rpm.html ) Read the number 5 posting and on. I believe I have the wrong speed sensor for my tach. My speedo is not working for one thing, and my 5th and neutral switch are not wired in to add to it.
I was told that I did not need to wire in those two switches in order to run the car. Does anyone know if that holds water for certain ?
Because before my five speed swap my sr was an auto(ha-ha... I know, it was cheap) and did not have any issue reving. It would go all the way to 7k with no prob.
So can anyone help me out ? And please dont tell me its the maf. I have read enough other postings on this issue to rule out the maf.
Do you suffer from vaginal dryness...
Pblesh85 is offline   Reply With Quote
Old 08-26-2008, 05:43 PM   #2
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
did you get the correct ECU?
Bigsyke is offline   Reply With Quote
Old 08-26-2008, 06:13 PM   #3
808_s13
808_s13's Avatar
808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future
pblesh, its the maf dude...
haha jk man. i know someone would say it,
i'd figure i'd say it first.
-makua[ace]
Originally Posted by ILoveMyRHS13;
Tomei or Megan? Is like comparing Trojan condoms and Ziplock bags.
808_s13 is offline   Reply With Quote
Old 08-26-2008, 06:40 PM   #4
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
All the tech threads and write ups that I read said you can use the auto ecu on a s13 5 speed swap.
So im still using the auto ecu. Does anyone know 100% whether or not you can use a auto ecu on a manual s13 blacktop ?
Old 08-26-2008, 10:10 PM   #5
DRFTER34
DRFTER34's Avatar
DRFTER34 has made poor choicesDRFTER34 has made poor choicesDRFTER34 has made poor choicesDRFTER34 has made poor choicesDRFTER34 has made poor choicesDRFTER34 has made poor choices
yes you can, My S13 SR redtop was using a automatic ecu at first, then crapped out on me then I got a manual one and it work the same as the auto one. I also had a KA24DE that was auto before i did my swap on my 240. I did the manual swap and i used the auto ecu and had no issues except for the cold start thing but I fixed that with the manual ecu no problems after that. With all of that in mind I had no Idle or rev issues, make sure all of your vacuum lines are connected and fuel lines as well. check FPR and injectors make sure there is nothing restricting the airflow from the MAF and fuel from FPR and injectors. If you want some real help go to www.heavythrottle.com and email those guys they are the SR masters, they helped me numerous times with my SR just let them know in detail what is going on they would be happy if you emailed them or if you called.
DRFTER34 is offline   Reply With Quote
Old 08-27-2008, 06:06 PM   #6
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
anyone have any thoughts ?
Old 08-27-2008, 11:10 PM   #7
Mikey88
Mikey88's Avatar
Mikey88 is on a distinguished road
are you getting codes? or is your engine light on?
Mikey88 is offline   Reply With Quote
Old 08-27-2008, 11:33 PM   #8
DRFTER34
DRFTER34's Avatar
Ive given you my side, make a check list and go from there eliminate things. FSM will help alot also.
Old 08-28-2008, 05:59 AM   #9
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
No check engine lights and everything else is normal.
I thought that s13's were before obd1.
Where do you plug in a scanner to a s13 ?
Old 08-28-2008, 11:34 AM   #10
DRFTER34
DRFTER34's Avatar
S13's are OBD1, OBD2 didnt happen till 1996 and up. Alot of your questions can be easily found in a FSM(Factory Service Manual) Im not sure if it would work depending on how you did your wiring.
