Old 09-20-2009, 07:26 PM   #1
89SwapXE
89SwapXE's Avatar
89SwapXE is an unknown quantity at this point
tranny wire harness
i know that the sohc and dohc tranny are the same but are the lower tranny harness the same? i got an 89 tranny with a 93 motor and i just got my dohc vss so i just wanna know if its just a plug and play thingy?
89SwapXE is offline   Reply With Quote
Old 09-20-2009, 08:13 PM   #2
projectRDM
projectRDM's Avatar
VSS is the same from 89-94.
The lower harness is different since the alternator and power steering pump are on opposite sides. You can shorten the alternator wiring or use a DOHC harness.
FORMERLY R240NA
Old 09-20-2009, 09:21 PM   #3
89SwapXE
89SwapXE's Avatar
so ur saying i have to swap out for the dohc harness..can i just change the vss? my speedometer doesnt work also
Old 09-21-2009, 11:39 AM   #4
Not You
Not You is an unknown quantity at this point
No just extend the wires, 95+ VSS are different you shouldent have a problem.
Not You is offline   Reply With Quote
Old 09-21-2009, 02:21 PM   #5
89SwapXE
89SwapXE's Avatar
ok so just extend the wire from the vss so it can connect to where ever its going to right
