Old 07-08-2008, 07:28 PM   #1
TEALSQUEAL
TEALSQUEAL's Avatar
TEALSQUEAL is making a name for him/her selfTEALSQUEAL is making a name for him/her self
s14 z32 ebrake set-up worth?
I have a set of Z32 ebrake hardware: all the inside hardware for the ebrakes when you have a z32 swap from the shoes to the springs, etc. I also have the Skyline ebrake cables that make it a bolt on affair none of that cutting cables and u-jointing it together crap.
What do you all think it is worth?
Looking to sell the package when i get home from this deployment
The ebrake hardware kit is low usage off a parts car my friend wrecked.
Thanks
Dave
TEALSQUEAL is offline   Reply With Quote
Old 07-08-2008, 07:34 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
maybe 160 bucks
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-08-2008, 07:47 PM   #3
TEALSQUEAL
TEALSQUEAL's Avatar
The ebrake cables are brand new in package, not used or stretched.
Old 07-09-2008, 02:58 PM   #4
952jz240sxr
952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices952jz240sxr has made poor choices
still not worth much to other people.
952jz240sxr is offline   Reply With Quote
Old 07-10-2008, 08:00 AM   #5
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
Thanks
Dave
Just search the forsale section it will tell you what each of those parts go for. 180 is what I last saw the ebrake assy go for. Cables were like 100 and conversion brake lines go for around that too.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
