03-01-2015, 12:38 PM | #1 |
New 1 piece driveshaft too long and now it's stuck
I have a J30 diff in the car and have been running the stock non abs drive shaft for a while.
I just got a 1 piece from the drive shaft shop for a ABS s14 and just installed it. It went in the trans fine but it seems like it was slightly too long. I gave it a good push to get it lined up to the diff flange but now it's stuck. I can't spin the drive shaft by hand and I can't get it off. Any ideas? I'm thinking maybe the dust shield is maybe a little too small and the new drive shaft has a larger joint at the end? But I can't even check it out because for the life of me I can't get the drive shaft off to check. |
03-01-2015, 01:26 PM | #2 |
Loosen the differential bolts that hold it to the frame. Or use a pry bar to pull some tension off the trans to slip it out.
My SR20VET |
03-01-2015, 01:40 PM | #3 |
Good ideas. I give it a try in a few hours.
Once I get the drive shaft out Im also going to check the prop shaft seal depth. I put a new one in and tapped it until it was flush with the end of the trans, maybe it needs to go in further. |
03-07-2015, 12:11 PM | #4 |
03-07-2015, 12:36 PM | #5 |
Most remove it altogether. Just cut an inch or whatever is needed off and tap it back on.
My SR20VET |
