For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
04-16-2012, 01:18 PM | #1 |
Trader Rating: (91)
Feedback Score: 91 reviews
Autometer Gauges, Triple Gauge Vent Pod, Angled Rings
Selling this gauge setup from my car. It's a 52mm triple gauge vent pod with angled rings. The gauges are 52mm autometer ultra lites. Mechanical boost and electric volt and oil pressure. The oil pressure sending unit will be included. I've also made a harness for the lighting and signal wires. All you need to do is run power and ground wires and a signal wire for the oil pressure sender. The boost gauge has a small ding in the bottom of the bezel but it has a barbed fitting on the back so you can use a rubber vacuum line instead of the cheap plastic tubing that it comes with. $150 shipped. PM or txt 515-537-7319.
www.monkeyboysyo.blogspot.com |
04-16-2012, 07:49 PM | #6 |
Trader Rating: (91)
Not looking to part. If you look at the bracket on the back of the boost gauge there is a hole. Theres a hole in all three. I used small bolts and wing nuts with a piece of aluminum.
04-16-2012, 08:03 PM | #8 |
Trader Rating: (91)
I bought the panel from a seller on ebay and bought the rings from jegs.
04-18-2012, 01:17 PM | #9 |
Trader Rating: (91)
Still for sale!
04-28-2012, 01:26 PM | #11 |
Trader Rating: (91)
Still have this!
04-29-2012, 09:25 PM | #12 |
Trader Rating: (91)
Sold.......
