Old 04-11-2008, 11:37 AM   #1
ROUGE180
ROUGE180's Avatar
ROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfection
Send a message via AIM to ROUGE180 Send a message via Yahoo to ROUGE180
Question S13 Power Steering pump Q
I have a finned Redtop with a bad P/s Pump. It whines realllllly bad and the fluid is frothy/bubbly. It's on its last legs. Does anyone know if there is a US counterpart that I can use if I cant source a genuine JDM P/S pump? Please let me know. Desperate right now.
Thanks
ROUGE180 is offline   Reply With Quote
Old 04-11-2008, 04:20 PM   #2
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
I actually have the same problem. Can't you use the KA pump on it with a different bracket? If the fluid lines all hook up the same, I may just do this.
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 04-14-2008, 05:15 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
IIRC you can use the dohc KA pump...you may or may not have to change the pulley.
CLICK HERE!!!
Old 04-14-2008, 10:58 PM   #4
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
You can use the KA DOHC P/S Pump but you need to use the SR bracket and the SR pulley.
