For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
Lots of Parts: Takata Nardi NRG SARD, Circuit Sports, HKS Greddy, more!
Takata Harness, short version, includes 5 point crotch strap: $250 shipped
real harness, FIA certified through 2011, was $450 new Takata Harness, long version, includes 5 point crotch strap: $sold Nardi 330mm classic, black leather with red stitching, includes horn button: $sold NRG 240sx Steering Wheel Hub, includes Nardi adapter on it: $sold miscellaneous circuit sports coolant reservoir: $sold carbing oil catch can: $sold brake master cylinder heat shield: $sold greddy type R blow off valve: $sold very large, can hold a lot of boost, has small crack in casting but does not affect performance HKS SSQV sequential blow off valve, old version: $150 shipped this is the older version, that doesn't suck. if you are looking for a bov that doesn't leak, this is it. NISMO Radiator cap: $sold holds more pressure, really helps with cooling SARD Fuel Pressure Regulator, with gauge: $sold SR20DET fuel rail adaptor, allows use of external FPR: $sold SARD 850cc side feed injectors for SR20DET: $sold includes adaptor rings for SR20DET OEM fuel rail, and brand new harness plugs. these injectors should handle whatever you throw at them. 3k miles on them, no problems with them SR20DET oversized water pump pulley: $sold prevents cavitation at high RPMs, uses stock belt EBay Toe Rods: $sold HKS hotpipe for SR20DET, with HKS blow off valve flange: $60 shipped real HKS hotpipe, great fitment Moroso master battery cutoff switch: $45 shipped brand new, very heavy duty switch, 4 pole for battery & alternator Hella H4 Conversion Housings: $sold glass housings, DOT approved. when i bought these, these were the only DOT approved housings available, not sure if there are others now Ollo German made 6k HID H4 conversion kit: $sold again, when I bought these, they were some of the best available KICS 15mm Bolt on Spacers, with HubCentric wheel rings. $sold KICS R40 Neo Chrono Lug nuts, 12x1.25 Nissan pattern. *$100 shipped 3 were damaged, so this is a set of 17, includes 14 lugs, 3 lock lugs. *perfect if you are 4 lug. 5 lug hubs Front: Peak Performance Street version S13 conversion hubs. *$150 shipped wheel studs have been trimmed on these to run 15mm wheel spacers. Rear: OEM S14 hubs and bearings (fits s13 also), both purchased brand new, 3k miles on them. *Peak Performance 50mm extended studs pressed in. *$160 shipped Last edited by mykem; 11-10-2010 at 02:39 PM.. |
#3 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
i'll take the sard FPR pm me your paypal address
Slip Gypsies Blog Quote:
![]() Join Date: May 2006
for those who dont know much about the HKS hotpipe. when bought new it came with the HKS BOV but for $400. i have the same one on my motor and it wasnt cheap
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html ![]() |
same wheel here: Nardi 330 mm Classic Steering Wheel Black / Black: eBay Motors (item 190463970081 end time Dec-02-10 19:29:11 PST) |
yep, this was back in the day before there were a lot of generic hotpipes. it was $400 new with the blow off valve that is also listed. in the end i guess a pipe is a pipe though =/
#9 | |
Trader Rating: (31)
sard FPR sold to me
![]() Join Date: Nov 2006
![]() ![]() Feedback Score: 9 reviews
Can you please get some better pics of the carbing oil catch can? I want to see if the stamping of where it says carbing, very interested, paypal ready, thanks.
![]() www.tm-spl.com Kouki's & some apple juice. |
#19 |
#25 |
#28 |
