s13 drive shaft issue
this just started about 3 weeks ago when i go to take off from a dead stop my shifter bounces up and down violently and they slower as i go faster and also when i take off i hearing a clanking coming from under the center console is my best guess. my first thought was carrier bearing so i replaced it and it helped but it still did it and now it does it as bad as it did in the first place. tranny mount and such and all good and tight. it still shifts fine and clutch is works fine. I'm at a lost for thought here. any help or suggestions?
![]() Join Date: Sep 2009
Trader Rating: (91)
![]() Feedback Score: 91 reviews
Did you check your motor mounts?
www.monkeyboysyo.blogspot.com |
Trader Rating: (91)
Solid as in how? Ive had "solid" poly tranny mounts crack on me.
I have the same exact issue with my s13, and i went the same route (replacing the center bearing) but it wasnt until I saw my friends dirveshaft months later, that I found out that the mounting mounting/support bracket has a bottom AND TOP piece, which secure the your driveshaft in place, keeping it from slaping the bottom of your car. (my car only has the bottom half of the bracket. Priced one from nissan was either $35 or $40 bucks for a new one.
Yes the bracket itself should be the problem. When you get your car in the air, inspect the center bearing it should be supported by a bracket on the bottom keeong it from falling and the 2nd half of the barcket onthe top to keep it from flopping around a slapping the car.
and this is the bracket.... based on the orientation of the picture.. the top is actually the bottom and vice versa for the other half. This is one instaaled on the driveshaft.
I'm no driveshaft expert, but seeing as most driveshafts have their weights attached by rivets, or have them welded on; I highly doubt that its become unbalanced especially with it being an oem unmodified part. And I'm assuming that havent gone mudding, off-roading, or run over some huge object causing abnormal strees or impact to it...so yeah I'm sticking with the bracket.
Welp then that will completely kill the issue as well, and you wont have to deal with any further carrier bearing issues. Z1 Motorsports has one-piece aluminum driveshafts for $278 (0_o).... and thats th lowest you're gonna find directly from an aftermarket supplier. But with whatever you decide good luck man(;-)
kouki man
![]() Join Date: Apr 2006
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
Check your diff bolt next to the drive shaft. If u have an s14 your diff has bushings next to the drive, bolt could be loose or bushings are worned out. S13 has no bushings though
#20 | |
Any updates!!
#23 |
just did an s13 auto to manual swap, and there is a loud whirring or whining sound when slowing down coming from the drivetrain area,(seems the driveshaft area), and also when reaching a certain speed when accelerating. Similar to a harmonic vibration. I think its probably a shot carrier bearing since its off a 92 w high miles. Hoping someone can confirm this, but based on the responses above, I'm thinking its a shot carrier bearing.
#24 |
![]() Join Date: Aug 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
mine would clunk and thunk off the line. the 6 puck clutch didnt help at all. replaced the driveshaft with a 1 piece last week and now its awesome. 1 thing to keep an eye on though, is that if you get any vibration with the new shaft, take it out and rotate 1/4 turn and see if the noise goes away. mine had to be rotated 180 degrees.
#25 |
![]() Join Date: May 2011
If you're pushing any sort of power go buy a drive shaft shop 1 piece drive shaft and call it a day. had this problem last summer with my SR. launched it and then every time i sped up the thing would clunk really bad. the carrier bearing or the mount, one of the two (i don't remember) went bad. I heard they don't like anything around 250 or so horse power. Plus it being old doesn't help. 1 piece steel or aluminum drive shaft and call it a day.
#26 |
Just got my 1 piece driveshaft from Z1 motorsports, woo hoo. Think I'll be installing that tonight.
to the OP: YOur shifter bounces up and down??!! how is that possible if its bolted to the crossmember. Is your clutch grabbing?
#30 | |
![]() Join Date: Jun 2007
That tidbit did fall under the "Jack Test" that is not for CV axle cars (like ours lol), but the principle is the same so far as rotating the shaft goes. Sounds wacky, and I don't fully understand it; but those guys know their sheit... and I now have a good idea why my alum shaft seems to be so noisy ![]()
Tags |
240sx coupe, driveshaft, rb20det, s13 |
