Closed Thread
Old 09-17-2010, 04:02 PM   #121
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
Originally Posted by mrflip69 View Post
Haltech Platinum Pro uses OEM knock sensor. I think the new AEM series use it too--Nistune obviously.
Plenty of people run PFCs without knock control though...
If you've got a good tuner, it shouldn't be a problem, but I figure it's always good to have an extra fail safe for those hot days and extra crappy gas.
I'm more interested to see you fit all the AC/rad/fan stuff though, as there's barely any room with my setup--but S14 has just a bit more room than an S13.
fitting it is easy, keeping it cool is the hard part.
Review Thread
bardabe is offline
Old 09-17-2010, 10:40 PM   #122
Sileighty_85
Sileighty_85's Avatar
Just got in my Steering overhaul package.
(I already got some Moog Outer Tie Rod Ends)
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Sileighty_85 is offline
Old 09-18-2010, 06:55 AM   #123
tricky_ab
tricky_ab's Avatar
Damn you've got great attention to details. Nice job on the harness.
tricky_ab is offline
Old 09-18-2010, 12:02 PM   #124
fender-startocaster
fender-startocaster's Avatar
fender-startocaster is an unknown quantity at this point
^ im with him! your attention in detail shows especially in how well documented your thread is.
fender-startocaster is offline
Old 09-18-2010, 09:23 PM   #125
Sileighty_85
Thanks Guys ^^
I believe in doing it right the first time with quality parts
Got everything installed today, I would have kinda done a step by step but didnt think about it at the time
A BIG noticeable difference after everything, Steering is much more responsive and stiff.
The Tein Tie Rods came with steering angle spaces.
I must say i never expected that a 1/4in metal ring would make such a noticeable difference in steering angle
yeah a def need to get some Angle adjuster tie rod ends
後輪駆動車1番
1986 SR86 - 200ish
Old 09-19-2010, 02:14 AM   #126
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
the tein tie rods are dope hey. i've got the same in my car
i took my car for a spin today and tested my turning radius , i was laughing the whole time.
you basically turn and your inside rear wheel is pretty much stationary
1992 240sx (RB20. [email protected])
eklips3 is offline
Old 09-21-2010, 10:15 PM   #127
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
M an your build looks exactly like mines with the exception of the new oilpan. Man i have been looking for the P/N for the front timing cover for like a week thanks for the info. I will post pics as soon as i get my timing cover and rocker covers in.
Think "satin wrinkle black"
redline racer510 is offline
Old 09-26-2010, 01:45 PM   #128
redline racer510
damn what happened to this build thread did it die or something lol?
Old 09-26-2010, 02:06 PM   #129
Sileighty_85
nah man its still happening.
I had to wait until my wifes GC interview in New Orleans before taking the next step.
Im iffy on my wiring harness so Im gonna send it off and have it checked over before pluging it in.
But I will start pulling the KA and dropping the RB in when it starts cooling off, or within two weeks
後輪駆動車1番
1986 SR86 - 200ish
Old 09-26-2010, 08:16 PM   #130
Sileighty_85
so anyone know for a fact or have pics if its possible to put the FAL fans on the Koyo Rad as pullers with Syko Mounts, WITHOUT cutting the Upper Core Support?
Im kinda not wanting to sandwich it behind the condenser, thinking it might not be efficient enough
後輪駆動車1番
1986 SR86 - 200ish
Old 09-26-2010, 08:41 PM   #131
Freddy
Freddy's Avatar
Freddy is an unknown quantity at this point
Man this build is making me think of doing a rb25 swap instead of ka-t, keep up the good work
Freddy is offline
Old 09-27-2010, 01:30 AM   #132
mrflip69
mrflip69 is an unknown quantity at this point
Dunno if it'll fit with your fancy condenser but with the stock one on an S14, you will be able to barely fit a clutch fan by just bashing the upper core support a bit if any.
..before time was so cool.. when people built long-term personal cars..
mrflip69 is offline
Old 09-27-2010, 03:14 AM   #133
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I had to cut my upper core support and drill new holes to move the radiator forward enough for the fan clutch to fit with my Koyo. Mckinney mounts.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline
Old 09-27-2010, 08:26 AM   #134
fender-startocaster
^^ that looks good but damn its missing a lot of the support. Could it be possible to obtain shorter radiator that would fit underneath the core support as if it was tucked in forward?
Old 09-27-2010, 03:12 PM   #135
OBEEWON
OBEEWON's Avatar
Ugh. So true. Im about to give up and take mine out. As of Friday I can no longer keep it cool with all the AC crap.
I want to put in my clutch fan so bad but I do not want to cut my rad support at all. Im on ZeroLift mounts and there is not much space. Even my E-fans are mm's from my pulleys.
OBEEWON is offline
Old 09-27-2010, 03:44 PM   #136
singlecamslam
Yea Rb's and cooling dont get along so well. I use pusher fans SO FAR so good. I'm with Obee i would hate to cut my support.
singlecamslam is offline
Old 10-03-2010, 07:26 PM   #137
redline racer510
sileighty85 Im debating the exact same thing and what I am leaning towards is the flexalite 106-398( these things are supposedly 1 3/8" thick). I'm thinking of mounting 2 of these in front of my condenser and fabbing up a piece of plastic that seals up the area around both of the fans to draw in the air while the car is at a stop and possibly a smaller fan on the other side that is controlled through a switch. I heard not even the FAL fans fit properly so upon reading about many other peoples setup the front pusher setup sounds ideal to me.
Old 10-03-2010, 07:49 PM   #138
asianbluesi
asianbluesi has a spectacular aura aboutasianbluesi has a spectacular aura aboutasianbluesi has a spectacular aura aboutasianbluesi has a spectacular aura aboutasianbluesi has a spectacular aura aboutasianbluesi has a spectacular aura about
Hmmmm.....you guys got me 2nd thinking the route I went with my fan setup. Since I live in the desert.....here in AZ, i ended up wiring up 3 mishimoto fans.
2 pushers (in front of the radiator)
1 puller (behind the radiator)
-The puller is always on.
-1 pusher is wired to turn on when the temp gauge needs it to
-Other pusher set up for when I use AC
Is this not an optimal/ideal setup?....should I have gone with the 2 flex-a-lite fans instead?
Sileighty,
I just recently found out about the pre-made wire harness conversion done by Yuri. I am in the same boat as you.....waiting for the RB25 S2 into a S14 chassis. Have you heard anything else from him? I want to get this pre-made harness asap....but dont want to wait another 2-4 months.
BTW....this is a great thread....keep up the excellent work!
Elmer
asianbluesi is offline
Old 10-03-2010, 09:03 PM   #139
Sileighty_85
Sounds good, Id make sure that the fans can push the 2500cfm (seems to be the best cfm)
Shit man if it works Id keep it.
Sileighty,
Elmer
Still in development, they were having issues with finding and ECU plug and are in the process of making them now. Still no date or ETC.
I'll be sending my harness I "Repaired" and "Converted" to Yury to have him inspect it, since the harness was so hacked up.
If i had an unfucked harness Id probably trust it but dont wanna risk frying my ECU
後輪駆動車1番
1986 SR86 - 200ish
Old 10-04-2010, 12:53 AM   #140
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
Hey pat how have those isis arms been holding up for you?
Small freaking world dude, chit chatted with a guy and his wife this weekend that said he was from Shreveport. I asked him if he knew you and the dude couldn't belive I knew you haha. I forgot their names but they were pretty cool. He said he was doing a rb vert, sbc hatch and a few coupes.
VQMaxFan is offline
Old 10-04-2010, 01:00 PM   #141
redline racer510
Thats what me and my friend did to our wiring harness for both the s15 sr and my s1 RB he seems like a pretty knowlegeable guy and plus me and wiring harness modification work dont get along,lol.
Old 10-04-2010, 11:03 PM   #142
Sileighty_85
ISIS arms are holding like a champ. No issues still
I dont know anyone doing an RB vert, but it might be this one kid i know up here. Not sure if its actually gonna happen though. From what Ive heard hes had quite a few projects that havent worked out all that well.
do you know if it was an RB 20 or 25?
Yeah ive done quite a good bit of bussiness with Yury, Been happy with every product and very helpful to boot even at 10:00 at night
後輪駆動車1番
1986 SR86 - 200ish
Old 10-08-2010, 08:39 PM   #143
Sileighty_85
So i finally got in my Hyper Gear Turbo
I wanted a turbo that bolted up to the stock exhaust and down pipe since i spent a good bit on the SYKO mount set. Not looking for 500hp just somthing more than stock so this turbo will do just fine
Key benefit:
360 degrees Thrust bearing Heat treated steel wheel and shaft Suitable for High Boost applications Product Goal: High Responds, High Torque. Long life time. OEM Bolton RB25det Upgrade.
sure i sacrifice the stock Ball Bearing system but now i got a rebuild-able turbo
Comparison between the Stock R33 turbo and the Hypergear R33 Turbo
Stock
Hyper Gear
Most noticeable difference is the Exhaust Wheel
The craptasic Ceramic wheel is replaces with a Steel turbine wheel
Stock
Hyper Gear
Ive been sick for the last 3 days but if i feel better I will begin pulling the KA on the S14 tomorrow
後輪駆動車1番
1986 SR86 - 200ish
Old 10-08-2010, 09:40 PM   #144
username
username is an unknown quantity at this point
If you dont mind me asking, how much was that turbo and where'd you get it from? I've been looking into one of these for my rb25. Also how much hp is this one rated for?
username is offline
Old 10-08-2010, 09:45 PM   #145
Sileighty_85
HyperGear - 450HP RB25det Hiflow Turbo
Conversion is moderately priced, Shipping is what pushes it over the top. It would be about $200 total in shipping since they are located in Australia.
Instead of sending my turbo to them they were able to locate a R33 turbo over there for the same price that it would cost to ship. So im able to keep the turbo an rock it if I were waiting on it to come in.
Originally Posted by Hyper Gear Email
The Max boost which the high flow can handle depending on the type of turbine housing that you want to send in or what we can find here. Generally standard RB25det turbine housing can handle about 16psi making about 240rwkws while the RB25detNEO turbine housings can handle about 18psi making around 260rwkws.
If you need we can provide the PU service which runs of a customized .82 turbine housing that is good for 20psi and 280rwkws .
The oil feeding line needs to have minimum of 3mm inner diameter including all the fittings on the way. We can supply the oil feeding line for $80AUD additional.
後輪駆動車1番
1986 SR86 - 200ish
Old 10-08-2010, 09:49 PM   #146
username
Thanks for the info. Yeah i think shipping costs is whats keeping me from going that route. Definitely a nice snag.
username is offline
Old 10-09-2010, 09:54 PM   #147
Sileighty_85
Alright guys Stage 1 is complete!
Finally had some free time to pull the engine
hmmm KA48
Hmmm what else needs to be taken out
ahhhh finally
Time to Power Wash
So after the engine bay is cleaned and IC piping Preped then I can drop the RB in.
Hopefully I can do it next weekend depending on how my work week goes
後輪駆動車1番
1986 SR86 - 200ish
Old 10-09-2010, 10:33 PM   #148
tricky_ab
tricky_ab's Avatar
Engine is out?...You must be pumped!
Old 10-09-2010, 11:14 PM   #149
Bubba Chaos
Bubba Chaos's Avatar
Bubba Chaos is an unknown quantity at this point
Glad to see your almost done... Seems like this is added up fast and indeed is an expensive build
Bubba Chaos is offline
Old 10-10-2010, 05:43 PM   #150
Sileighty_85
Indeed I am I cant wait to hear this baby roar
Yeah It has. its almost been a year now since I bought the clip.
Mainly been waitin on parts and a wire harness
後輪駆動車1番
1986 SR86 - 200ish
Closed Thread
rb25 install, rb25 rebuild, rb25 s14, rb25 swap
