#32 |
Im sorry if youre butt hurt because I call things like I see them. Reality check buddy, you said yourself you're going to "mechanic" school. Which tells me you do not have the skill set to pull off the swap. It's not negativity, it's called being a realist.
My SR20VET |
#33 | |
Take your retarded ideas over to the Honda forums please. Thanks.
#34 | |
A dumbass is someone that believes everything he sees without questionning it first. A dumbass makes assumptions based on feelings and intuitions, not on facts. A dumbass doesn't ask or think before he talks, because his primitive emotions are so overwhelming, he has to react. Therefore the dumbass (you) is just an emotional little girl stuck in a grown man's body. A realist bases himself on reality, and the reality is, you don't know what the fuck or who the fuck, as a matter of fact, you're talking to - I'm a realist. I have all the material and skills necessary, but if you would know, Captain McFuckingSmartass, welding a front clip's firewall with the full front to another vehicle's frame can't be done in any DIY workshop. It needs to be cut precisely, aligned and it needs to be welded and welded PROFESSIONALLY if the car is to be driven everyday. But I'm sure you already knew all that. Unless Junior here would like to drive on the highway one day and have his real car bend in real half, and have his real car spin out and have a real crash. (Which would be great for the humanity and planet earth but I don't wish that any of these things happen to you.) Now, if you have that experience, if you have those skills (something that I highly doubt based on your basic reasoning and homosapien-like logic #realistcrew) please, by any means, tell me what I need to do. I will listen to you and value your time and knowledge. But if you don't have anything constructive and valuable to say other than your biased, bitch-made and useless opinion which as no other purpose but to shoot down one of my dream projects, I'd advise you show yourself out, buddy. |
#35 | |
I'd say first of all they would inspect your car as a modified car, and it would be classified as a VGA vehicle from the get go. If you're planning on welding a whole front clip in : Also, they would run extensive testing on the rigidity and alignment of the frame and quality of welding of the parts added to the firewall (Hole for the pedals, pedals, power steering rack etc etc). If you just wanna do the conversion : This welding job can't be done by your average joe, you don't want your pedals to give in when your driving or racing around. But I'd put on quality of the assembly + the additional inspection that goes for a VGA/Modified vehicle. Firewall strenght and integrity, power steering and pedals quality of welds etc etc. Basicly everything you've touched or might have ''compromised'' I have heard by someone in the import game that some garages that do the inspect won't even mention the RHD (which I don't know if I would be able to sleep at night with) to the SAAQ or the prior RHD history of your car. Now if you're planning to do a conversion, I wouldn't take the firewall out and weld another one in. Id simply try to find a LHD interior and power steering column and I'd try to convert my rhd. |
#36 |
#37 | |
Why wouldn't you be able to sleep at night if they don't mention the RHD history of your car? |
#38 | |
#39 |
Any person with the knowledge, skill set and tools can do this at home, which would make it DIY. No one with the ability to do what you want comes to a forum to ask for random persons input on how one could do this swap. Therefore, based on your silly ass question, you do not have the skills or tools to pull it off. However, you're either to deft or stupid to figure out that this little dream project is illegal for anything but track use. Perhaps you should define illegal for yourself before you piss away money on this silly project to break the law, see jail time, lose more funds for any governmental repercussions and surely have your car crushed or yarded for it's life. By the way, above is based on factual information and is not the opinion of one or more persons.
With the above said, if you'd still like to continue with your idiotic attempt at "fooling" the law, we can start with the basics. The car needs to be leveled and secured. Now, I'm sure you don't have a frame machine(a body shops best tool) at home nor do most, but jack stands will be your friend. Once the car is secured, measured, and absolutely level, start by removing everything forward of the B pillars. This includes the glass, all harnesses, brake, clutch, fuel, steering rack and interior pieces and anything else running from the middle of the car forward. Leave the cross member in for rigidity. B pillars you say? Those would be in the middle portion of the car, where the doors latch. Once everything has been pulled out.There are multiple ways to pull it off. You can hack it together like most would, or you can do it right, by remove all the spot welds that hold it together. There are probably a few hundred to drill out, you'll have to find and mark all the ones needed. I suggest getting a spot weld cutter, fancy tool that makes a nice clean cut. Once/If you get to this point, it's basically reverse. You'll obviously need a donor front clip so you can do the same exact thing to remove the firewall/bulk head. When you get it out, clean it up, make sure you use weld through primer, on all areas that will get welded back in. Well, you should be able to figure out the rest with the knowledge and skill set you have. No sense in holding your hand anymore. Oh, the FSM has all the dimensions you'll ever need. In the end, I understand this is a "dream" project. I know it's "your" money and this is what you want to do, but it's dumb regardless. Breaking the law isn't condoned anywhere, unless absolutely necessary. If you think you're going to casually fly under the radar with a converted car of that severity, good luck. A stated earlier in this silly thread, a LHD car is no different in terms of motor/transmission and ECU setups. Easiest option for you is to register your car with a friend of relative in another providence to get you JDM tyte RHD.
My SR20VET |
#40 | |
#43 | |
I'm not challenging you in any way, I'm genuinely curious to find a way to achieve my dream of owning an S15 and actually being able to use it. |
#44 | |
Now, I'm not saying you should do that. In the event you should get in to a horrible drifting accident, killing a family or injuring someone, everyone on that slip is eligible to be "gone" after for retribution. Keep that in mind.
My SR20VET |
#45 |
![]() Join Date: May 2010
Can you just buy a LHD car, then take a RHD car and move all the parts over?
If you're taking this on, I highly suggest you spend time POURING over images and other peoples' builds. You should be intimately familiar with what goes where and how/why things are engineered (both RHD and LHD), especially both sides of the firewall. Once you do that you can build your parts list in your head and develop a plan. At this point though, I think your problems are not going to be so much technical or mechanical, but political. |
#46 |
AFC #1
![]() Join Date: Oct 2003
From what I can understand from the ramblings in this thread you are looking for methods to bypass laws. We don't allow these types of discussions so, this will now be closed.
Comments should be taken as Opinions not as Statements of Fact ![]() |
Tags |
240sx, conversion, lhd, rhd, silvia |
