Old 10-30-2017, 12:06 PM   #1
G-Sep
G-Sep is an unknown quantity at this point
S14 Power window during rebuild
Hey guys, have run into an issue with my power windows. I need to get them rolled up on my S14 but I am currently in the middle of a rebuild on the engine. Not sure if I need the engine harness in to get power to the windows. I have tried just hooking the battery up to the positive terminal at the fuse box and got nothing except for the time display in the gauge cluster. Any help is much appreciated.
G-Sep is offline   Reply With Quote
Old 10-30-2017, 12:12 PM   #2
Standard
Unplug window motor and apply 12 volts to the prongs in the plug, power and ground. If it dissent go up or it goes down, reverse polarity and it should roll up
Old 10-30-2017, 12:22 PM   #3
G-Sep
Thank you! I was trying to avoid pulling the door panel but if that's what I have to do then so be it.
Old 11-01-2017, 09:10 AM   #4
SteeleBrothersDrifting_Mike
SteeleBrothersDrifting_Mike's Avatar
SteeleBrothersDrifting_Mike is an unknown quantity at this point
You can hook the battery back up just tape your starter and alternator leads. Make sure you have a ground hooked up and battery isn't dead.
SteeleBrothersDrifting_Mike is offline   Reply With Quote
Old 11-03-2017, 05:50 AM   #5
G-Sep
Ahh alright, those leads on the engine harness. I'll give that a shot tomorrow.
