08-18-2012, 10:29 AM | #1 |
Need s14 SR20 crank pulley ASAP. Help!!!
Please help with any knowledge. I need a crank pulley asap for my s14 sr20. My stock just shifted forward I am guessing it’s done. Where can I buy it and hopefully not to expensive.
08-18-2012, 01:56 PM | #4 |
Man w/ CTSV & a Car Seat
OEM is more than good enough...unless you're making a 600hp engine, there's really no for an aftermarket crank pulley.
But if you insist on an aftermarket one... ATI Super Damper (Main Pulley) - SR20 |
08-19-2012, 06:52 PM | #5 |
08-20-2012, 07:44 AM | #6 |
Thanks. I ordered oem crank pulley but does anyone has an easy way to replace it. I tried searching on here for how to replace it but could not find anything. Thanks
Sent from my MB855 using Tapatalk 2 |
08-20-2012, 04:52 PM | #7 |
get a pulley puller and you're more that likely going to need to pull out the radiator in order to fit the puller in there. you might be able to get it off by hand but it's at a pita spot to get to by hand so you can try it and get a puller later if unsuccessful.
10-10-2012, 04:43 PM | #9 |
I had success pulling my pulley off w/a 3 claw puller. It fit without removing the radiator. Remove the fan clutch (if installed) along w/the accessory belts. Back the crank pulley bolt out an inch or so, but don't remove it all the way. This gives the claw puller a center to push against (the crank pulley bolt has a dimple in the center and makes this easier).
FREE DNB & DUBSTEP MIXES |
