Old 06-29-2005, 10:06 AM   #1
Colorado S14
Colorado S14 is on the path to ruinColorado S14 is on the path to ruin
BMI videos why do the driver tap the brakes?
When you watch the driver in these videos you will see them tapping the brake pedal a few times when they are not braking. What is up with this?
Colorado S14 is offline   Reply With Quote
Old 06-29-2005, 10:42 AM   #2
ayes
ayes is an unknown quantity at this point
weight shift
ninja vanish
ayes is offline   Reply With Quote
Old 06-29-2005, 12:06 PM   #3
AKADriver
AKADriver's Avatar
AKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura about
Yeah, could very likely be trying to load up the front of the car a little bit.
Also, it might be a "sanity check" or if the track is wet they could be cleaning the rotors. My 240SX never really had a problem with it, but my old VW GTI, whenever it rained really hard, the brakes would build up a thin film of water while driving at speed that I needed to "wipe off" with a tap of the brakes.
AKADriver is offline   Reply With Quote
Old 06-29-2005, 05:40 PM   #4
thx247
thx247 is an unknown quantity at this point
Pad knockback
in a turn the clearances between caliper, rotor, hat and all the other items on the knuckle allow the rotor to push the pistons back into the caliper slightly. Next time you get on the brakes the 1st (2nd or 3rd) pedal push is spent moving the pistons closer to the rotor and not braking like you wanted to.
You can google it for diagrams and stuff if you want. I have not had a problem with it on the 240, but if you ran race tires it might be a problem possibly. I don't know.
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
Old 06-30-2005, 01:46 PM   #5
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
or it could be they are making sure they have pressure in the lines. a couple of pumps while your driving ensures that brakes are gonna be there when you actually NEED to use them. better to find out on the straight than when you need to be breaking for that hairpin.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 06-30-2005, 08:34 PM   #6
Hikarispeed
Hikarispeed's Avatar
Hikarispeed is an unknown quantity at this point
Send a message via AIM to Hikarispeed Send a message via Yahoo to Hikarispeed
That's the main reason I recall from watching races on tv and what commentators say.
Kaizen Racing
Hikarispeed is offline   Reply With Quote
