![]() Join Date: Mar 2010
1981 Toyota Corona - 1JZ - Coilovers & More
The short list: 1981 Toyota Corona
JZA70 SUPRA 1JZ Non-VVTI ($1500) R154 5-speed transmission ($1500) Custom driveshaft ($400) Recently replaced stock twin turbos, stock 10psi FMIC ($200) 550cc 2JZ injectors ($150) Walbro 255 ($100) 3" exhaust w/ custom dual blast tip (extra: flanged db compliant muffler) Front X7 Cressida KOUKI caliper & rotors X7 BC Coilovers (10K) ($1000) T3 X7 angle knuckle ($150) T3 AE86 tension rods ($150) T3 custom tie rods ($150) X6 Cressida extended LCAs ($50) Rear BC coilover shock & springs (8K) T3 AE86 panhard ($150) Rear End MK1 Supra diff housing ($600) Rebuilt MK1 Supra LSD ($50) Weir LSD shim kit, brand new bearings, seals, everything assembled by The Rear End Shop, Livermore, Ca ($800) Dual-caliper hydro T3 AE86 dual caliper bracket ($320) PBM hydro assembly & Wilwood master ($135) SS lines ($180) S13 rear calipers S13 Hawk HP+ pads ($80) Interior Bride Zeta I (2) ($800) Defi Link console with BF Turbo, Water temp, Oil temp ($550) Nardi Classic 360MM ($200) Tom's pedal covers ($50) Exterior Levin Vertex style front bumper (2), one on car is done, have an extra in good condition ($150) SC300 ED skirts ($150) S13 coupe bmagic style 326 power style wing ($200) LED strobes front & rear w/ controller Wheels F: Work Meister S1 15 x 9J -15 ($1000) R: Advan Oni 15 x 10J -28 ($1200) I'm likely forgetting some details, but you get the picture. Testing waters, just looking for cash unless you have a stock/close to stock 4-door e7 corolla plus cash. Pictures are from a while back, the Onis have been rebarreled. ![]() ![]() ![]() ![]() Last edited by roushman90; 06-30-2016 at 11:33 AM.. Reason: update |
#13 | |
Will vouch for rad car |
Tags |
1jz, ae86, toyota |
