Old 10-27-2008, 11:37 AM   #1
doubledashdrifting
doubledashdrifting is an unknown quantity at this point
SR sr20det whinning sound, like supercharger.
I have this very high pitched whinning sound from the front of my engine. It happens no matter if the car is cold or warmed up, gets louder when rpm increases. I thought it was my tranny low on fluid so I checked and it was low, filled it up and still have whinning sound. Opened my hood and noticed the sound is the loudest from the front of the engine area, either the crank pully or alternator, heck or water pump. Not sure what would cause this sound, like the title says, it sounds like a high pitched supercharger whine. Can this be the Alternator going bad, water pump, or something worse? Any info would help.
doubledashdrifting is offline   Reply With Quote
Old 10-27-2008, 11:41 AM   #2
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
belts.
could also be ps pump going out.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 10-27-2008, 04:18 PM   #3
doubledashdrifting
the sound does not get worse when I turn the wheel, it only gets louder if I bring the rpm's up. is there any way to quickly check if its the water pump or the alternator or if its something else.
Old 10-27-2008, 09:52 PM   #4
doubledashdrifting
Ok so its not my steering pump. The sound is louder by the crank pully, my front main seal is leaking could that cause the bearing in the pully to make this whining sound? It getting worse and louder, need to find the cause asap. Any suggestions?
Old 10-27-2008, 09:54 PM   #5
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Oil pump died. Stop driving asap
blu808 is offline   Reply With Quote
Old 10-27-2008, 10:20 PM   #6
Sileighty_85
Sileighty_85's Avatar
Remove all your belt and crank it if sounds persist look deeper
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-28-2008, 12:07 AM   #7
doubledashdrifting
hey blu808, any way to 100% find out if it is the oil pump, I'd hate to buy a pump and do all that work for the sound to be there again.
Old 10-28-2008, 12:08 AM   #8
doubledashdrifting
I will try that tomorrow. I hope its something simple.
Old 10-28-2008, 02:48 PM   #9
doubledashdrifting
Ok I ended up taking the car to a guy on the Nico forums that works on 240's. He noticed that my front main seal is leaking bad and said most likely the cause for this sound is the front main seal. He is gonna replace it on Thursday or Friday, hopefully this fixes the problem, but need to do it anyway so bonus if it does fix the sound.
Old 10-28-2008, 03:09 PM   #10
surge s14
surge s14's Avatar
do you run a fan clutch?
it happend to me on my old ka
all i did was get e-fans and done
surge s14 is offline   Reply With Quote
Old 10-28-2008, 03:20 PM   #11
doubledashdrifting
no I am running duel electric fans, but I know that the crank pully looks pretty damn old and my front main seal is REALLY bad.
Old 10-28-2008, 03:37 PM   #12
Om1kron
Om1kron's Avatar
heh he would've been in trouble a looooong time ago if this were the case.
Wayne
Old 10-28-2008, 03:54 PM   #13
doubledashdrifting
Yeah, I'm also getting oil up to the cams so doubt its the pump...ok, hope its not the pump but yeah I've had this sound for a while now and my engine would have died long ago if that was the case.
Old 10-28-2008, 07:27 PM   #14
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
most likely cause is the alternator.
jspeedm is offline   Reply With Quote
Old 10-29-2008, 12:05 PM   #15
doubledashdrifting
I've done the poor mans stethoscope, long screwdriver, on the alternator and I'm not hearing the noise.
Old 10-29-2008, 05:58 PM   #16
jspeedm
jspeedm's Avatar
Trader Rating: (26)
that will only tell you if the bearing or pulley is bad. if it is the windings inside the alternator, the screwdriver wont tell you. if you have a friend with the same car, borrow his, swap them, and the noise should be gone.
Old 10-30-2008, 10:55 AM   #17
doubledashdrifting
LOL, I actually already purchased a used sr20 alternator, I'll get it tested and if that one is good I will probably just install it. Thanks for the info Jspeedm.
