Old 11-22-2008, 04:20 AM   #1
zilvialatorre
zilvialatorre's Avatar
zilvialatorre is an unknown quantity at this point
idling too low on ka24
hi cn someone help me how to fix the idling on my ka24...it idles at 500 to 600 rpm..is that normal? can i adjust it higher that wont hurt the engine...
thanks for the help guys,,
zilvialatorre is offline   Reply With Quote
Old 11-22-2008, 08:54 PM   #2
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
check for vacuum leaks. if no leaks. adjust the idle air control valve to raise the idle
ch1873857 is offline   Reply With Quote
Old 11-26-2008, 04:37 PM   #3
Ghost05
Ghost05 is an unknown quantity at this point
don't forget to advance you're timing, but don't advance it all the way or you'll start knocking.
Ghost05 is offline   Reply With Quote
