Check Engine Light on 1995 S14
Hi, I recently took off my transmission to replace my clutch. After driving for a couple of miles, the Check Engine Light came on. I also noticed that the car is running kind of rough. It does not feels the same.
Does anyone know how to check the error code? I took it to Autozone and Advanced Auto, but they told me that they can't do cars 1995 and older. |
![]() Join Date: Dec 2002
You broke the CPS when removing the transmission. Common on our cars. Although that itself would not cause the car to run any differently, so follow the FSM's procedure for pulling codes, you have something else wrong too.
![]() Join Date: Sep 2003
'95's have an OBD plug that will work with a generic OBDII scanner. They're being lazy.
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free. |
Thanks for your responses. Yeah I found the OBD II Connector on the passenger side. I never thought that a 1995 will have a OBD II.
Anyways, here are the codes that showed up: P0340 Camshaft Position Sensor A Circuit P0325 Knock Sensor 1 Circuit P0335 Camshaft Position Sensor |
The CPS is broken, just as I said. 99% of people don't remove it before pulling the transmission, it's plastic and breaks easily when smacked against the flywheel. Knock sensor could be a dozen symptoms, read up on how it works and why it goes off on here and virtually any decent search engine.
Tags |
1995 s14, cel, check engine light |
