Old 06-27-2014, 12:35 PM   #1
livelovesole
livelovesole is an unknown quantity at this point
Any input on ID725cc injectors ???
Piecing the last few parts for my build and I was going with Nismo 740s but heard of some idling issues with them. Read up and was advised ID725s which seems and sounds great on paper so far but cant really find any reviews on them. Any input helps, thanks.
S13 Blacktop
Tomei M7960 Turbo 16-20 psi
Tomei Exhaust Manifold
Freddy Intake Plenum
RS-Enthalply Tune
Stock Block
JWT S3 Cams
livelovesole is offline   Reply With Quote
Old 06-27-2014, 02:45 PM   #2
quickdiversion
quickdiversion is an unknown quantity at this point
I went from nismo 740cc injectors on a power fc originally and they we very easy to setup and getting working very well. I went to ID1000 cause of my new power needs and they are rather difficult to get right. They are finally nice with idle, but They open up fast and over spray easily. Tuff to get right.
Not sure about the ID725cc ones though
quickdiversion is offline   Reply With Quote
Old 06-27-2014, 03:02 PM   #3
livelovesole
yeah i could imagine with such big output. i want to run into minimal issuses with it seeing how i wont have a standalone to fine tune it
Old 06-27-2014, 03:26 PM   #4
quickdiversion
Yeah I would go with the nismo 740cc if you do not have a stand alone. Here are the settings and info I used with mine.
Nismo (16600-RR544) / Tomei (195017) / Apexi (404-N006) / HKS (1402-RN009)
aka JECS 740cc injectors (side feed, high impedance, circle, red)
voltage: msec
8v: 1.641
10v: 0.973
12v: 0.633
14v: 0.463
16v: 0.359
18v: 0.227
Nismo 740cc injectors
high impedence
.66 latency
I am pretty sure when it comes to fuel injectors, they are all bought from the same company and rebranded, so all there setting should be the same. According to this.
Old 07-01-2014, 10:13 PM   #5
rbs14kouki
rbs14kouki's Avatar
Aem ems , id2000 , c16 fuel
idle like stock at around 900/1000 rmp
You wont have any problems with some 750cc on a good tune
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
