07-16-2008, 08:25 PM | #1 |
Ka24de ceramic coated pistons & IC question
I aquired some ceramic coated pistons and as you can see from the pics there is some slight dings on the piston lip. Can this be repaired? Would it be safe to install in this condition?
Also the same for the IC. The rear portion has a slight bend at the bottom. Should this be any MAJOR concern? Ive seen worse but just though Ide ask. Thanks
