Old 02-28-2009, 11:33 AM   #1
xs042sx
xs042sx is an unknown quantity at this point
630cc injectors on s15t
im on 15 lbs on my s15 turbo on s14 blacktop how will 630cc injectors run on it?
xs042sx is offline   Reply With Quote
Old 02-28-2009, 11:54 AM   #2
projectRDM
projectRDM's Avatar
What tune? Fuel management?
If you're asking if you can just stick larger injectors on the car, no. If you have have something to tune with they'll work just as good as any other injector upgrade. It's not like 630cc is a magic or weird number.
FORMERLY R240NA
Old 02-28-2009, 11:55 AM   #3
xs042sx
what about 550cc i still needa tune?
Old 02-28-2009, 11:57 AM   #4
projectRDM
projectRDM's Avatar
Yes. How do you think the ECU will recognize the bigger injectors? You have to do something to alter the signal, otherwise the ECU will still be looking at the stock 480s, no matter what.
Go read up on injector sizing and tuning before you go any further.
FORMERLY R240NA
Old 02-28-2009, 12:00 PM   #5
xs042sx
safc2 will tune my car?
Old 02-28-2009, 12:01 PM   #6
projectRDM
projectRDM's Avatar
Yes.
message length
FORMERLY R240NA
Old 02-28-2009, 12:05 PM   #7
xs042sx
okay thanks and what do you think will be the right size injectors?
Old 02-28-2009, 12:07 PM   #8
Devil Man
Devil Man is an unknown quantity at this point
hahahahahaha
Devil Man is offline   Reply With Quote
Old 02-28-2009, 12:13 PM   #9
projectRDM
projectRDM's Avatar
The size that you put in I guess. I don't know your car, your parts, plans, goals, or anything.
But I'm done. Your questions have been answered. Research more, it's obvious you're unsure about what you're about to get into.
FORMERLY R240NA
Old 03-01-2009, 12:43 PM   #10
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Well 550's will work 630's will work the stock ones will work too. You need to tune appropriately for the amount of boost you are planning on. I'd personally go higher with the 630's to give you some room to work with down the road.
godsmack is offline   Reply With Quote
