Old 04-10-2019, 07:29 AM   #1
Chikeen
Chikeen is an unknown quantity at this point
Engine dies when going from third or fourth or fifth to neutral
hi guys. my engine is dying if i am in either third fourth or fifth and go to neutral. also it dies if i go above a certain a rpm. any advice? im running a ka24de with various mods, including a 248 248 cam swap.
Chikeen is offline   Reply With Quote
Old 04-10-2019, 09:32 AM   #2
Kingtal0n
Kingtal0n's Avatar
whats the wideband doing when it happens
-its probably the maf placement-
Old 04-10-2019, 01:45 PM   #3
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
This or a huge vacuum leak
Old 04-10-2019, 07:17 PM   #4
Chikeen
I have no Wideband
Old 04-10-2019, 11:52 PM   #5
Kingtal0n
Kingtal0n's Avatar
well then how do you expect people to diagnose an issue based on fuel? How do you know how much fuel is going into the engine and whether or not its burning properly?
If you want a guess its probably maf placement related. The maf requires non turbulent positioning, with straight pipe on both ends, and it needs to be placed far enough from the turbo and throttle body to avoid the small perturbations caused by the compressor wheel and water hammer effects of a shutting valve.
Other than that it could be a slew of issues, from air leaks to bad Oxygen sensor but without a wideband to backup data its just guesses. Need much more info
or suggest trying standard procedures,
compression test,
pressure tests (crankcase and intake pathways)
timing test
Old 04-11-2019, 08:27 AM   #6
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
+1 for we need more information.
-was it running good before?
-did you CHANGE something, and then this started happening?
-when you say "various mods" we have no idea what that means. intake and exhaust? 300 shot of nos? roots style blower? cmon dude you've gotta provide useful information for us to be able to help you
Old 04-11-2019, 12:38 PM   #7
Chikeen
Short Ram
Intake K&N with stock MAF
Battery moved to drivers side
4-2-1 headers
Full exhaust system with 2.5 outlet
Coilovers Emusa
Custom seats with Tamata Belts
ebay Short shifter
Dual Exhaust Cam Swap 248 248
Ventilated Disks
Diff LSD 300zx
Strut bars (rear & front)
Gas Regulator
Electronic Fan
Z32 Fuel Filter
These are all the mods. I don't have a Wideband because the previous owner never got to putting it, and I am on the process of doing it. Then again, Im a broke college student lol.
Old 04-11-2019, 12:51 PM   #8
brndck
brndck's Avatar
Originally Posted by Chikeen View Post
Short Ram
4-2-1 headers
Coilovers Emusa
ebay Short shifter
Ventilated Disks
Diff LSD 300zx
Gas Regulator
Electronic Fan
Z32 Fuel Filter
its definitely the ebay short shifter causing the problem
start by checking for vacuum leaks
Old 04-11-2019, 01:51 PM   #9
Chikeen
actually never gave me a problem. its been great so far. all the trouble started when i deleted the apexi safc 2 piggyback
Old 04-11-2019, 02:01 PM   #10
brndck
brndck's Avatar
what are you using for cam gears? iirc the 248/248 cam gear swap needs an adjustable cam gear to get the new cam into correct position.
Old 04-12-2019, 10:27 AM   #11
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
I see a short ram intake, how far away is the MAF sensor from the throttle body?
Old 04-15-2019, 03:06 PM   #12
Rubber D
Rubber D's Avatar
Rubber D is a well-known jackass
Safc??.. do you have the stock maf and injectors?
Rubber D is offline   Reply With Quote
Old 04-19-2019, 02:58 AM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Better yet, were there fuel trim corrections in that SAFC. Either way, car is bogging because its running rich when he comes off the throttle.
CLICK HERE!!!
