10-05-2017, 02:45 PM | #1 |
S14a (notchtop) to VVL Conversion
Greetings...
Have 1970 Datsun 240z with SR20DET Notchtop engine (see current mods bellow) and would like to do VVL conversion.. have couple questions.. would appreciate, already used search feature.. Can i run current ECU/Harness with ROM tune? - Currently have NA ecu code with JWT ROM tune for current mods.. since Engine is VTC i wondering if can it be used to trigger VVL. Does SR20DET RWD intake manifold fit VVL head or need to purchase aftermarket intake manifold? Any suggestions? Located in San Diego Area.. Current car/mods: 1970 Datsun 240z Engine: 1998 Silvia S14a(kouki) SR20DET Notchtop Tomei Poncams GT2871r Turbo N62 Maf 550cc STI Injectors HPI Turbo Manifold JWT 4 Bar tune R200 3:90 Rear diff Blitz FMIC, Blitz BOV, FPR, supporting mods, 14psi of boost for now. 19190888_10155487047877502_178087273_n.jpg 22154418_10155871792202502_5788363835984535586_n.jpg |
10-05-2017, 02:53 PM | #2 |
I have a p11 vvl motor with sr20de jwt ecu with a msd window switch for the vvl and it works flawlessly as long as you are running the right fuel maps. Running stock de harness as well.
10-05-2017, 03:04 PM | #4 |
Yes this will work, but it will not work ideally. The ideal setup would be a real standalone that has multiple auxiliary input and outputs such as a AEM or Haltech unit. Does SR20DET RWD intake manifold fit VVL head or need to purchase aftermarket intake manifold? Any suggestions? No it does not, you'll need an aftermarket intake such as the Mazworx one. Mazworx actually makes a full VVL swap kit that has all of the pieces that you'll need for the swap http://www.mazworx.com/store/p/105-M...-Manifold.aspx http://www.mazworx.com/store/p/96-Ma...rsion-Kit.aspx You will also need to get a VE oil pump, SR20VET pistons, and a couple of other miscellaneous parts but I covered most of the big ticket items. |
10-05-2017, 03:05 PM | #5 |
i dont think so but then again it could be different since the ecu im running was for a de motor which had nothing of that sort. I would contact jwt to confirm. Had my tuner burn a chip 93 oct and correct fuel maps for vvl.
10-05-2017, 03:48 PM | #7 |
I think you need to visit the VE thread. All and I mean every single one of your questions has been answered and in detail.
You will need a window switch to control VVL. If you have anything other than OEM pistons, you'll need to fly cut or replace the existing pistons. OEM pistons can be run with a thicker headgasket. I recommend a piston with valve reliefs if you plan to go that far.
My SR20VET |
