Old 05-10-2020, 07:06 PM   #421
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Little update - not much changed. Just cleaning up the bay a bit and throwing some wheels on the front to finally match the rears.
Some goodies from Driftmotion to help in pretty up the bay.
GKTech RCC Kit and Eccentric Lockout Kit
ESR SR04's 18x9.5+22 but running a 12mm spacer to clear brakes wrapped in Federal 595's 215/40/18. Car needs more low up front now. Ill be dropping it after I install the GKTech RCC Kit I bought along with DIFTech knuckle adapter sleeves I never realized I needed
Driftmotion power steering reservoir I had literally just bouncing around in the bay for years... I picked up a Chase Bays reservoir bracket and drilled 1 extra hole and it worked out super nice. Threw on a new turbo feed line, turbo blanket and the billet caps for the engine oil and ps reservoir. Waiting on the correct chase bays bracket to mount to a new coolant res by them.
Bracket I used for anyone looking to mount their DriftMotion res
https://www.chasebays.com/products/c...UaAgqgEALw_wcB
Slapped on the old front bumper again to high that massive front mount. Definitely time for a proper kit
Few random shots with my cousins clean ass Starlet
More updates coming soon! Got a digital dash on the way and im pretty excited about that one to finally have a working cluster again.
BiG MiKE86 is offline   Reply With Quote
Old 05-12-2020, 04:15 PM   #422
BiG MiKE86
BiG MiKE86's Avatar
Nice package came in today! Finally getting dash back in the car now with this bad boy.
Almost fits like it was meant to be there. Ordering a sheet of ABS plastic to mount the cluster to and it should be good to go
Sent from my iPhone using Tapatalk Pro
Old 05-13-2020, 05:21 PM   #423
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE's Little Build!
Installed the AIM MXS Strada 1.2 and customized a few pages and the splash screen. This thing is worth every penny!
https://www.youtube.com/watch?v=bDJ5QgMcnO8
Old 05-14-2020, 03:54 AM   #424
DIENOW
DIENOW's Avatar
DIENOW is an unknown quantity at this point
Originally Posted by big mike86 View Post
installed the aim mxs strada 1.2 and customized a few pages and the splash screen. This thing is worth every penny!
https://www.youtube.com/watch?v=bdj5qgmcno8
siiick, mike!
DIENOW is offline   Reply With Quote
Old 05-14-2020, 03:54 PM   #425
EF_jaycee
EF_jaycee's Avatar
EF_jaycee is an unknown quantity at this point
is that 4age in the corolla? it looks sweet all chromed up with the hks cam gears
EF_jaycee is offline   Reply With Quote
Old 05-14-2020, 04:00 PM   #426
BiG MiKE86
BiG MiKE86's Avatar
Originally Posted by DIENOW View Post
siiick, mike!
Thanks Spen!
Old 05-14-2020, 04:01 PM   #427
BiG MiKE86
BiG MiKE86's Avatar
I believe is a 3SGTE? Something out of an MR2 I believe - not entirely sure.
Old 05-16-2020, 02:11 PM   #428
BiG MiKE86
BiG MiKE86's Avatar
I was in the market for pigtails to finally get all my front lights working. Missing the pigtails for the corners and finally found them.
Ordered some from Wiring Specialties that work!!!
https://www.wiringspecialties.com/connectors1.html
https://www.wiringspecialties.com/canesaswco.html
Perfect fit and brand new connectors. Its a shame to see folks on ebay selling a pair of beat up pigtails with 1" of wire for $30-$40! Get yourself these and you'll be set.
Old 05-21-2020, 08:15 PM   #429
BiG MiKE86
BiG MiKE86's Avatar
double post
Old 05-21-2020, 08:16 PM   #430
BiG MiKE86
BiG MiKE86's Avatar
https://www.youtube.com/watch?v=-K7aMNs-mfg
Quick clip of the first burnout. Car feels solid and smoother than ever
Old 06-09-2020, 09:25 AM   #431
ph1tnessjunk1e
ph1tnessjunk1e is an unknown quantity at this point
This is a killer build and fun to read through. Thanks for keeping this updated and being detailed!!
Originally Posted by BiG MiKE86 View Post
I wasnt having any success with the Xcessive engine/trans brackets so I ordered Get Nuts Lab engine and trans brackets as well as the matching steel 1 piece drive shaft thru Ace Up Motorsports (Awesome to deal with - spoke to Vitaly). So the brackets came within 3 days and boy did they look and feel much better than the Xcessive pieces (no offense to Rich whom has been awesome in dealing with and will be refunding my $$$ for the stuffs).
Hoping to swap out brackets this weekend. Ill be using my old SR nismo mounts and an MK3 trans mount with these brackets.
FYI problems I had with the Xcessive mounts, engine brackets, trans bracket.
-Hood wouldnt close
-Engine mounts didnt sit flat on brackets
-Trans bracket didnt line up well with trans mount (~1" off front front to back)
Is this a common problem with the Xcessive engine mounts? I think I'm running into the same problem you had, I can't get the brackets to sit flush on the mounts.
ph1tnessjunk1e is offline   Reply With Quote
Old 06-09-2020, 09:28 AM   #432
afishysilvia
afishysilvia's Avatar
Trader Rating: (30)
Feedback Score: 30 reviews
+ A million for the bread trick. You must be a mechanic by family generations or have a good old friend. Only other time I?ve seen that is from an old mechanic buddy of mine.
Sweet build, makes me itch to drop my 2J
afishysilvia is online now   Reply With Quote
Old 06-09-2020, 03:06 PM   #433
BiG MiKE86
BiG MiKE86's Avatar
Thanks for the compliments!
I see a bunch of people running those brackets I just wasn?t thrilled with the fitment and went another route. What engine mounts are you running with the brackets?
Old 06-09-2020, 03:08 PM   #434
BiG MiKE86
BiG MiKE86's Avatar
That bread trick I actually picked up on YouTube but definitely been wrenching most my life following the older generations in the fam
Thanks
Old 06-09-2020, 07:31 PM   #435
ph1tnessjunk1e
I?m using the mounts Xcessive recommends for a lower profile
https://xcessivemanufacturing.com/xm...h-umm-s15.html
Old 06-09-2020, 07:33 PM   #436
BiG MiKE86
BiG MiKE86's Avatar
Shit 2.6? is tall af - I have solid aluminum blocks @ 2.125 and my hood just barely closes
