Old 01-24-2009, 04:33 PM   #1
nrmskate
nrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enough
Adjusting Idle
Well, I have a KA24E, and it's idling at about 500rpm
I have tried the Idle Adjustment Screw.
Only other suggestion is the throttle cable.
nrmskate is offline   Reply With Quote
Old 01-24-2009, 04:43 PM   #2
RPS13-604
RPS13-604's Avatar
RPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really nice
i do not understand your post haha
RPS13-604 is offline   Reply With Quote
Old 01-24-2009, 05:30 PM   #3
nrmskate
I want to up the idle to about 1000-1200rpm, but the screw is not working.
Ive turned it clockwise all the way and vis versa while the car is running and no change.
And I was suggesting the only other way to adjust the idle would be through the throttle cable?
Old 01-24-2009, 06:45 PM   #4
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
you probably have something wrong with your sensors. maf maybe?
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 01-25-2009, 04:35 PM   #5
windshieldwiper
windshieldwiper is an unknown quantity at this point
clean your throttle
windshieldwiper is offline   Reply With Quote
Old 01-25-2009, 04:42 PM   #6
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Spray some carb cleaner into your intake piping.
Theres an adjustment bolt in the back, behind the intake manifold. Its behind a yellowish triangle support with a hole bored through it.
SochBAT is offline   Reply With Quote
Old 01-25-2009, 05:25 PM   #7
nrmskate
I know, thats what im saying, Ive tried that screw.
Nothing.
And isn't it bad to spray carb cleaner? I thought it was Intake cleaner?
Old 01-25-2009, 05:30 PM   #8
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
No theres nothing wrong with spraying carb cleaner. To adjust your idle though I believe you have to disconnect the TPS or adjust it with the engine off then turn it on and see.
duffman1278 is offline   Reply With Quote
Old 01-25-2009, 10:06 PM   #9
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
^ That's what I've always heard.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 01-26-2009, 12:00 AM   #10
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
maybe your iac was removed and adjusted wrong. did you check your computers diagnosic screw? i know of an instance where it wasnt put back to its original position and it idled wrong. btw 1000-1200 at idle is to high
supreme_1 is offline   Reply With Quote
Old 01-26-2009, 12:03 AM   #11
d3m14n
d3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of lightd3m14n is a glorious beacon of light
Send a message via AIM to d3m14n
idle should should be at roughly 650-750rpms
http://www.d3m14n.com/
d3m14n is offline   Reply With Quote
