Old 08-27-2008, 06:15 AM   #1
drkidd22
drkidd22 is an unknown quantity at this point
Stock Boost sensor.
Does the SR ECU NEED the signal from the stock boost pressure sensor or can it be taken out? What does the ECU use this signal for?
drkidd22 is offline   Reply With Quote
Old 08-27-2008, 07:28 AM   #2
Sileighty_85
Sileighty_85's Avatar
You can ripp it out if your using another boost controller
the Engine uses that sensor to maintain stock boost levels
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-27-2008, 09:22 PM   #3
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
apparently the sr runs at 11psi stock with that thing installed. i have never seen that myself, and i always thought sr was 7.5psi stock... leave it in and see for yourself
aNskY is offline   Reply With Quote
Old 08-27-2008, 09:32 PM   #4
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
throw it away
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 08-29-2008, 01:45 PM   #5
drkidd22
There are two things in the stock SR. The boost pressure sensor near the TB and there is also the wastegate valve controll solenoid connected to the wastegate (boost controller). Take both of them out? or just the boost solenoid?
