Old 02-05-2010, 03:09 AM   #1
CUSTOM VERT
CUSTOM VERT's Avatar
CUSTOM VERT is an unknown quantity at this point
RB IS there another way to make a RB25DET tranny
i was wondering if there is another way to make a tranny for a rb25det like switching bell housings on another tranny or anything
thanks.......
CUSTOM VERT is offline   Reply With Quote
Old 02-05-2010, 05:44 AM   #2
Couped_up'd
Couped_up'd's Avatar
Trader Rating: (47)
Couped_up'd is an unknown quantity at this point
Feedback Score: 47 reviews
-You can switch bell housings with a z32.
-You can use a rb20 tranny on a rb25.
-You can use a ka trany with a rb20 bell housing.
Couped_up'd is offline   Reply With Quote
Old 02-05-2010, 06:53 AM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
correct. the cheap way is to use an rb20 tranny. all the clutchs and flywheels are the same (except some 26's are pull type)
i used a 26 front bellhousing on a z32 5speed N/A tranny with a maxima slave cylinder (both bolt holes are on the bottom)
you could also use a 25 front bellhousing on a z32, the 20 won't work because it's too small.
gl
Dave
RB25 280z GT30/76R 441hp/381tq [email protected]
Z U L8R is offline   Reply With Quote
Old 02-05-2010, 05:10 PM   #4
CUSTOM VERT
so you can or cantuse a rb20 tranny ...im just looking for a cheaper way out bec my rb25 tranny stil moves the car butdoent stay in gear
Old 02-05-2010, 05:16 PM   #5
eh?
eh? is an unknown quantity at this point
You can use the RB20 tranny.
Have you taken the tranny to a shop? It's pretty much the same internally as the Z32 tranny.
eh? is offline   Reply With Quote
Old 02-05-2010, 09:33 PM   #6
Z U L8R
Z U L8R's Avatar
you can use a complete rb20 tranny, but you cannot use an rb20 bellhousing on a z32 or rb25 tranny because it's too small. you can however mix and match z32, rb25 and 26
Dave
Old 02-06-2010, 08:55 AM   #7
RACETUNE
RACETUNE's Avatar
RACETUNE is on a distinguished road
Send a message via AIM to RACETUNE
thanks.......
we use it on SR20DET engine for our drift car. What we do is cut the bell housing and weld half of the SR20DET to the RB25. If you want that, Garage BOSO can do it or send it to Japan they also do it.
-Garage BOSO-
-Racetune Engineering-
RACETUNE is offline   Reply With Quote
