Old 02-11-2013, 08:23 PM   #1531
2stepGoesPowPow
2stepGoesPowPow's Avatar
2stepGoesPowPow is an unknown quantity at this point
Originally Posted by 2muchboost View Post
Obx for $300 here
OBX TURBO MANIFOLD HEADER 93-98 SUPRA 2JZ 2JZ-GTE T4
Go with the 44mm wastegate...you won't be sorry.
yeah but with shipping it probably gunna come out to the same ebay shipped price. and why do you say that about the 44mm?
2stepGoesPowPow is offline   Reply With Quote
Old 02-12-2013, 07:36 AM   #1532
2muchboost
Trader Rating: (33)
Feedback Score: 33 reviews
If you ever choose to go for higher boost pressure and/or higher power goals you wont have to switch out. Depending on your turbo and boost pressure, if your WG is too small it will cause the turbine (on the turbo) to spin excessively due to back/overpressure. With a 44mm you have some wiggle room even with the smaller framed turbos.
Old 02-12-2013, 02:23 PM   #1533
PG BOOSTED
PG BOOSTED is an unknown quantity at this point
Good info @2muchboost
-Alex Bailey /18/ Orlando, FL / ⭐Founder of Straight Six Gang⭐
PG BOOSTED is offline   Reply With Quote
Old 02-12-2013, 03:53 PM   #1534
cchondro
cchondro is an unknown quantity at this point
Question
I have -8 lines on my fuel cell as of now should I keep these, will they be sufficient enough
I'm using a Warlboro 255 pump
cchondro is offline   Reply With Quote
Old 02-12-2013, 03:56 PM   #1535
BoostedVR4
BoostedVR4's Avatar
BoostedVR4 is an unknown quantity at this point
Originally Posted by cchondro View Post
Question
Talking with Freed, I also have -8an feed line, and -6an return. He told me this should be fine for my power goals of 650-750whp.
I have a single Bosch 044, and would like to add a 2nd towards the end if needed. I have to decide on having them both Y into a -8, or run two seperate -6 lines to a dual feed rail.
BoostedVR4 is offline   Reply With Quote
Old 02-12-2013, 04:14 PM   #1536
cchondro
That's kind of what I was thinking
I need a new return line because it was rubber and its going bad so I wasn't sure if I should get another -8 steel braided or bump both up to -6
but thanks for the help man
I'll run a -6 return and keep the -8 feed line
Old 02-12-2013, 05:54 PM   #1537
cchondro
Also, do you guys know what size banjo fitting do you use for the stock fuel system
Just want to make sure it's 12x1.25 like the stock fuel rail
Old 02-12-2013, 05:58 PM   #1538
afracer
afracer is an unknown quantity at this point
I've got a JDM Sport Ebay manifold for a whopping $95. Surprisingly needed very little massaging on the flange at all, really could've bolted it on as is, but I opened up the wastegate and ports a bunch with a die grinder to maximize performance/flow. You're not getting anything different with an OBX for 3x the price, so save yourself some cash, it's a cast manifold and it's more than likely going to outlast anything else on the car.
afracer is offline   Reply With Quote
Old 02-12-2013, 06:15 PM   #1539
2muchboost
Trader Rating: (33)
Walbro 255 will not push the limits of a -8 line....you have plenty of wiggle room.
@Boosted....I have a -10 line running to the front of the car then splitting (Y) into dual -8 lines into my FIC -8 Dual Feed Rail. Kept the stock return which is -6.
@AFRACER....I agree. There are plenty of threads about the log and tubular manifolds on SF. I have seen multiple 800+rwhp setups running the "El Cheapo Tubular Manifolds" with little to no modding needed.
@PG....No problem I will share whatever info I can provide. Been doing research on this build for over 3 years spending countless hours reading posts.....feel like a real winner writing this lol.
Old 02-12-2013, 09:17 PM   #1540
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
Where did you find that? cheapest one I could find was the speed racer performance for US $129.99
Mr. Phonso is offline   Reply With Quote
Old 02-13-2013, 09:42 AM   #1541
turbo-2ns
turbo-2ns is an unknown quantity at this point
for the guys running auto(if any) what shifter did you use
turbo-2ns is offline   Reply With Quote
Old 02-13-2013, 09:47 AM   #1542
RaNMaN
RaNMaN is an unknown quantity at this point
there are some differences worth mentioning but i will agree that they are minimal.
#1 - wastegate port size. every cast manfold that i have ever seen for the 2jz has a 38mm size wastegate port flange and cast material is not easy to weld onto either if you are thinking about opening it up and welding on another flange.
#2 - tubular vs. log style manifold. both can make awesome power but their shape and design place the turbo, wastegate and downpipe in slightly different locations.
RaNMaN is offline   Reply With Quote
Old 02-13-2013, 09:57 AM   #1543
Flicktitty
Flicktitty's Avatar
i used the factory S13 240sx one (I'd assume S14 is the "same") I had to cut and weld a little extension onto A340 shift linkage and it worked, i'll see if i can snap a picture if you need.
Old 02-13-2013, 10:26 AM   #1544
turbo-2ns
thanks pic would be awesome
Old 02-13-2013, 08:41 PM   #1545
afracer
Also used the stock auto shifter, cut the end of the 240sx shift rod off and welded it at the proper length onto the Aristo shift rod. Then had to drill a new hole in the shifter where the rod mounts up to a little higher to get the pendulum/arc correct (otherwise if Park is Park, 1st gear ends up somewhere around Neutral on the shifter). I thought I wrote this up a page or two back...
Old 02-13-2013, 10:02 PM   #1546
Flicktitty
Flicktitty's Avatar
AFRACER - Do you have any more pics of your car/build?
Old 02-14-2013, 09:42 AM   #1547
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
http://www.suprastore.com/suoilcoandfi.html
Anyone use their oil cooler yet? Looks like a well built kit for a nice price
BiG MiKE86 is offline   Reply With Quote
Old 02-14-2013, 09:44 AM   #1548
cchondro
Mishimoto sells a kit for 250
Old 02-14-2013, 09:45 AM   #1549
Flicktitty
Flicktitty's Avatar
thats not a bad price for drop in and go, Suprastore has had alot of bad reviews though! so be careful. Also it doesn't say what company any of the parts are, So it could be all Ebay stuff grouped into a package deal. I built mine using Earls/Aeroquip stuff for >$300
Old 02-14-2013, 09:48 AM   #1550
BiG MiKE86
BiG MiKE86's Avatar
Did you eliminate the factory cooler? If so which threaded nipple did you use? Using a thermostat? Have the part numbers nearby? I guess I'll keep shopping Around for other options or just piece together a kit
Thanks
Old 02-14-2013, 09:49 AM   #1551
BiG MiKE86
BiG MiKE86's Avatar
Link? Reviews?
Old 02-14-2013, 11:59 AM   #1552
cchondro
Universal Oil Cooler Kit, by Mishimoto
I plan on running this one if I run into cooling issues
Old 02-14-2013, 12:26 PM   #1553
cchondro
Can someone please shed some light on where in the hell im supposed to get this adapter
I need a -8an to 12x1.25 adapter
I found a -6an to 12x1.25 adapter on drift motion.com
But I cant find a -6an female to -8an adapter
All i find are -8an to -6an reducers
So Im looking for ether a
1. -6an to -8an adapter to work with the driftmotion adapter fitting for the stock 1jz rail or
2. Im looking for a -8an to 12x1.25 fitting.
Thank you to anyone who can help me out with this.
I also asked before but ill ask again,
I also need to find a 12x1.25 Banjo fitting for -8an
Ill be running -8an fuel lines for feed and return, ive decided against mismatching sizes for feed and return and now need a Banjo Fitting.
Or am I aloud to run a 12x1.25 AN Fitting directly into the stock fuel pressure regulator instead of a Banjo fitting,
If someone can assist with this also it would be greatly appreciated.
Old 02-14-2013, 12:59 PM   #1554
turbo-2ns
call stan at Talk to us !
Local/Int'l: (817) 439-3748
Toll Free: 1-877-988-8726
if they make it he would have it or can get it, tell him Brandan sent ya
Old 02-15-2013, 02:20 AM   #1555
afracer
Supraforums.com
I have more pics, but have not uploaded them yet.
Old 02-15-2013, 03:38 AM   #1556
PG BOOSTED
Has anyone gone BPU with this swap? If so can you possible provide info and pictures(if possible) of it.
Old 02-15-2013, 11:20 AM   #1557
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
Oil cooler
So people are running without a oil cooler and no over heating issues?
RickS14 is offline   Reply With Quote
Old 02-15-2013, 01:57 PM   #1558
RaNMaN
i have some old pics at home, i'll try to remember to upload them for ya later tonight.
are you talking about an aftermarket oil cooler or the factory water circulation oil cooler? i've been running my 2jz 240 since 2005 without any additional oil cooling and have never had a problem with it.
hell, i was even thinking about removing the stock piece that has the oil filter mount and getting the correct size piece so that i can just thread my oil filter directly onto the block. guys say that doing this will increase your oil pressure ~20 psi. if you ask me serious oil cooling only comes into play if you are road racing like doing laps around a circuit.
Old 02-15-2013, 02:06 PM   #1559
PG BOOSTED
Ok dude thank you.
Old 02-15-2013, 06:19 PM   #1560
RickS14
RickS14's Avatar
Sweet
Good to know.thanks for the reply. Yea if I don't need a oil cooler I won't run one.
