Old 01-08-2012, 06:50 PM   #1
WhipsGoneWild.net
WhipsGoneWild.net's Avatar
Trader Rating: (18)
WhipsGoneWild.net is an unknown quantity at this point
Feedback Score: 18 reviews
rb25 s2 pcv
hey guys quick question and yes i have been searching but can a s1 pcv interchangable with s2/ vise versa? I read that 20 and 26s wont work on 25 but got s2 and only found part number for s1 and i need one asap! lol
i assume it is faulty - completed boost leak and couldnt hold pressure noticed air coming from filter on right valve cover so unhooked hose from catch can to pcv and blocked the hose and was able to hold 10psi.. makes sense bad pcv right??
been a long day always appreciate comments and input
WhipsGoneWild.net is offline   Reply With Quote
Old 01-08-2012, 07:02 PM   #2
Sileighty_85
Sileighty_85's Avatar
NissanParts.cc - Your #1 Source for OEM Parts and Accessories
You actually need to run that VC nipple to the turbo intake (with a catch can in the middle) Cuz thats actually a Vacuum leak going on depending on blow by. plus it will help seal the rings better under boost
EDIt: what the Hell is your catch can connected to?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-08-2012, 07:56 PM   #3
WhipsGoneWild.net
Trader Rating: (18)
haha yeah thats a shitty pic but catch can is inline with the pcv valve. just basically replaced that small hose from pcv and put catch can inline where the hose was if it makes sense
Old 01-08-2012, 08:06 PM   #4
Flaco S14
Flaco S14 is on a distinguished road
if i remember correctly i used one from a KA or 300zx one of those where a screw on so not that one. and you can just get a new grommet from local auto parts store
Flaco S14 is offline   Reply With Quote
Old 10-04-2014, 07:26 AM   #5
rastaman
rastaman is an unknown quantity at this point
Back from the dead..what is a good part # for a pcv valve replacement from advance or local part stores? Can't seem to find one. I don't want to run catch can. Thanks for the help.
rastaman is offline   Reply With Quote
Old 10-04-2014, 06:10 PM   #6
rastaman
What PVC valve does RB use?
Old 10-04-2014, 08:23 PM   #7
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
oem nissan
part # 11810-75T00
part # for the insulator 11812-41B00
ANVIL is offline   Reply With Quote
Old 10-04-2014, 08:28 PM   #8
rastaman
I need one I can buy in the local auto store
Old 10-05-2014, 03:16 AM   #9
ANVIL
ANVIL's Avatar
Give them the oem nissan number they can cross reference it
