Old 05-10-2011, 10:01 AM   #1
epik1
epik1 is an unknown quantity at this point
Deck install S14
Hey guys, I need some help.
Deck I got:
DSC_0073 by wilwmak, on Flickr
What I'm dealing with:
DSC_0058 by wilwmak, on Flickr
DSC_0057 by wilwmak, on Flickr
DSC_0056 by wilwmak, on Flickr
DSC_0055 by wilwmak, on Flickr
DSC_0054 by wilwmak, on Flickr
DSC_0053 by wilwmak, on Flickr
Help?...I is noob.
Thanks
epik1 is offline   Reply With Quote
Old 05-10-2011, 10:15 AM   #2
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
I'm not hating but since you have no clue what you are doing just go to some audio place and have them install it for you for under $50.
KevinEdgar is offline   Reply With Quote
Old 05-10-2011, 10:16 AM   #3
nissanguy11
nissanguy11's Avatar
nissanguy11 is an unknown quantity at this point
Been there before....ITS HELL!
Constant 12V+ - Red/Black
Switched 12V+ - Blue
Illumination - Red/Blue
Dimmer - Red/Yellow
Left Front (+) - Blue/White
Left Front (-) - Blue/Yellow
Right Front (+) - Brown
Right Front (-) - Brown/White
Left Rear (+) - Red
Left Rear (-) - Green
Right Rear (+) - Purple
Right Rear (-) - Pink
...maybe that will help, then you will have to find out which wires are which on the head unit.
nissanguy11 is offline   Reply With Quote
Old 05-10-2011, 10:21 AM   #4
mikeroy420
mikeroy420's Avatar
mikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-known
Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers
Try this website, I found it really useful.
mikeroy420 is offline   Reply With Quote
Old 05-10-2011, 10:24 AM   #5
A54
A54's Avatar
Trader Rating: (40)
A54 is an unknown quantity at this point
Feedback Score: 40 reviews
nice color code info...
A54 is offline   Reply With Quote
Old 05-10-2011, 06:47 PM   #6
epik1
Dimmer - Red/Yellow
Left Rear (+) - Red
Life Saver!
..I have no idea how I'll find out which wire is what though from the headunit..thats where harness comes in play?..
Old 05-10-2011, 06:58 PM   #7
spooled240
spooled240's Avatar
you'll have to check with the manufacturer, if I remember correctly they are not the same colors as the 240 but should be relatively universal
Old 05-11-2011, 11:45 AM   #8
epik1
I'm good with which leads go to which speaker now! Thanks guys!
but the power I'm a bit confused cause this threw me off:
The .pdf install guide: http://www.docs.sony.com/release/CDX...stallation.pdf
States that the Red wire should be +12V Ignition and that Blue is "Antenna REM" (dunno)
But in the wiring coming from the car, Blue is connected to the Red and along the Red wire there's a 20A fuse..:S help?
Old 05-11-2011, 11:48 AM   #9
epik1
Dimmer - Red/Yellow
Left Rear (+) - Red
Illumination and Dimmer aren't in the manufacturers deck install guide, and those wires aren't out like the rest of the speaker wires.
But thanks for your help!
Luckily the harness coming off the deck matches the wiring coming out from my car. lol
Old 05-11-2011, 12:03 PM   #10
epik1
Also, anyone have ideas on where I can pick up screws for the deck?..didn't come with any..my local hardware store? Computer store? Fastenal? LOL
Old 05-11-2011, 12:12 PM   #11
Clearalbino
Clearalbino will become famous soon enoughClearalbino will become famous soon enoughClearalbino will become famous soon enough
Yes their M8 and very short! also the antenna wire is used for power antenna if you have one. The blue wire coming off the red wire was most likely a remote turn on for an aftermarket amplifier.
Clearalbino is offline   Reply With Quote
Old 05-11-2011, 12:20 PM   #12
epik1
Ok worst comes to worst I can cut M8 screws down to size lol.
So I can just unhook the red wire from the blue wire and use the red wire like its supposed to right?
What do I do about the 20A fuse thats spliced into the red wire?
Old 05-19-2011, 01:19 AM   #13
Kouki_Mnster
Kouki_Mnster's Avatar
Kouki_Mnster can only hope to improve
Cut and splice using the red wire, keep the fuse. you dont need the fuse but it will protect your headunit so why not.
Just in case you need a diagram with conversion from old color to new,
The Install Doctor - Radio Wire Harness and Colors - Nissan Infiniti
Kouki_Mnster is offline   Reply With Quote
Old 05-19-2011, 01:57 PM   #14
epik1
Yeah I kept the fuse in. Installed the deck, passenger speaker is blown =( lol
Thanks everyone!
