Old 08-12-2008, 06:24 PM   #1
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
SR Eliminating TB Coolant Lines SR20DET?
Hey Guys im in the final stages of finishing my motor build - Just wondering how/if I could eliminate the cooolant lines going into the throttle body? Thankx for the help
BiG MiKE86 is offline   Reply With Quote
Old 08-12-2008, 06:45 PM   #2
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
yes, Get a 3/8ths barbed fitting I believe, and find the 2 coolant parts on the TB, disconnect, and couple with 3/8ths brass coupler.
I would go as far to insulate the coolant lines running under the IM.
Bigsyke is offline   Reply With Quote
Old 08-12-2008, 08:41 PM   #3
BiG MiKE86
BiG MiKE86's Avatar
insulate how? why? thanks for the info +rep
Old 08-12-2008, 08:52 PM   #4
Jordan-S13-Silvia
Jordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the rough
Im intrested in doing this also but i wonder is their any bad effects that would happen after rerouting the the TB coolant lines.
400+HP on Topmount coming soon.
Jordan-S13-Silvia is offline   Reply With Quote
Old 08-12-2008, 09:28 PM   #5
BiG MiKE86
BiG MiKE86's Avatar
from what i understand those lines to the TB are mainly for colder climates to keep the TB from sticking... obviously down here in South FLorida I dont need this
Old 08-12-2008, 09:33 PM   #6
Bigsyke
Bigsyke's Avatar
IMO even in colder climates you might not need it, KA's put out alot of heat. I did this on a civic in -20*f and nothing ever froze.
There is some NASA looking shit from DEI you can get that velcros around the coolant lines.
Old 08-12-2008, 11:35 PM   #7
blownmotor
blownmotor's Avatar
blownmotor is on the path to ruinblownmotor is on the path to ruin
I just looped it around and bypassed the tube under the throttle body. Plus coolant constantly runs through there and makes the throttle body hot thus comprimising the cold air going through.
blownmotor is offline   Reply With Quote
Old 08-12-2008, 11:41 PM   #8
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
I had it like that untill 3 days a go. I was having cold start problems so i decided it to put the coolant again into the TB . i still have the cold start problems after i did the coolant lines to TB. my mechanic says it ill put hot air inside ur intake . i dont think it ill make that much of a different. ive run it with and with out , feel no different at all. if u want to do it just use the one next to the block and connect it to the one next to coolant temp , pretty simple .
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 08-14-2008, 08:54 AM   #9
BiG MiKE86
BiG MiKE86's Avatar
Oh kool thanks bro - i was gonna use a hose to hose splicer - but running the line direct sounds much neater - thanks! +Rep
Old 08-14-2008, 09:35 AM   #10
smelly240
smelly240's Avatar
smelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfection
i dont have the lines to the TB or IACV anymore i dont think... at least i know the iacv ones are gone.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 08-14-2008, 10:24 AM   #11
Bigsyke
Bigsyke's Avatar
IMO the whole thing is kinda useless on a KA. The bleeder screw and upper rad hose is connected to the IM anyways, so looping the lines and even a thermo IM gasket wont help.
Old 08-14-2008, 11:37 AM   #12
BiG MiKE86
BiG MiKE86's Avatar
The IACV doesnt need those lines? It doesnt affect its performance?
Old 08-14-2008, 11:59 AM   #13
Bigsyke
Bigsyke's Avatar
For the TB, if you live in colder weather, its not a huge deal.
For the IACV, if you live in colder weather, keep it!
For warmer climates loop them, but I highly suggest getting very good clamps, and do NOT stretch the hoses in anyway. Pin hole leaks will thow you whole cooling system off.
If you do reconnect then lines, you HAVE to get new coolant hoses, because the 3/8ths barbed couplers will stretch them open, and it will never seal correctly again
Old 08-14-2008, 03:19 PM   #14
BiG MiKE86
BiG MiKE86's Avatar
awesome... Ive already installed the IACV Lines but the TB will be gettin looped today
Thanks!
Old 08-15-2008, 02:07 PM   #15
BiG MiKE86
BiG MiKE86's Avatar
Well I ran the TB Coolant lines like RoidMonkey recommended and it came out fairly clean and it was pretty simple - Ill post pics later
Old 08-15-2008, 02:24 PM   #16
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
You can knock the fittings right out of the throttle body for a cleaner look as well
nsn240 is offline   Reply With Quote
