Old 07-22-2004, 05:54 PM   #1
run
run is an unknown quantity at this point
S14 wiring swap
I'm swapping a S14 Blacktop motor into a 97 240sx. I was just wondering if the wiring that you have to do to it is the same as doing a S13 redtop wiring? Does anyone know if it's the same? And if they are different. What is the different on the wire?
Thanks
run is offline   Reply With Quote
Old 07-23-2004, 04:41 AM   #2
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
no they're not the same. Your 97 is OBDII. The s14 (zenki/kouki?) blacktop might be obdI. There are threads on the wiring. Search button is your best friend
driftingisgay.com
nrg is offline   Reply With Quote
Old 07-23-2004, 11:51 AM   #3
run
thanks for the info. If anyone have a link to the wiring that will help me too. again thanks anyway.
