Old 01-22-2012, 09:15 AM   #1
doitsidewayz
doitsidewayz's Avatar
doitsidewayz is an unknown quantity at this point
S14 window problem. Quick question
Ok well finally got tired of not being able to use my driver side window. I thought the motor went bad but I jumped it and worked fine. So it was either my switch or amp. Every time I press the switch I can hear the AMp make a sound. So thought the switch is fine is the amp. Car is a 95 and I was wondering if an s13 amp would do tue trick? I was searching and this guy said it worked on his 95 zenki. So just wanted to check with y'all guys.
Thanks in advance guys!
-Agustin
doitsidewayz is offline   Reply With Quote
Old 01-22-2012, 12:06 PM   #2
yellowxhoodie
yellowxhoodie's Avatar
yellowxhoodie is an unknown quantity at this point
Take the amp out and open it up.
Youll see some solders that arent complete, just resolder everything and youll be fine.
Thats how I fixed mine.
There are walkthroughs online, just google it.
yellowxhoodie is offline   Reply With Quote
Old 01-22-2012, 01:40 PM   #3
doitsidewayz
Thanks you sir!
I was thinking about it but it looked like a pain to open it just by looking at it. But I don't loose anything by trying.
Old 01-22-2012, 02:09 PM   #4
SRTFerg
SRTFerg's Avatar
SRTFerg is an unknown quantity at this point
I have some spare window amps laying around if you need one.
Welcome to zilvia, we kick bitches in the face from our high horses.
SRTFerg is offline   Reply With Quote
Old 01-22-2012, 04:07 PM   #5
doitsidewayz
^^^^ awesome. Ima try to solder it if not ill let you know asap.
Old 01-22-2012, 04:25 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You cant always eyeball the amp. My amp looked good, didnt have any bad solder or anything burnt up. I just ended up buying a new one from Courtesy Nissan for like $25-30. Why use a used one that will just go out again due to age when you can just buy a new one for half a tank of gas.
CLICK HERE!!!
Old 01-22-2012, 04:38 PM   #7
doitsidewayz
Oh..I thought it would be around 100 or more..you know stealerships over pricing on everything
Ima still try to fix this one I got and I will go from there. Thanks a lot guys
Old 01-22-2012, 04:57 PM   #8
Promise Land
Promise Land's Avatar
Promise Land is an unknown quantity at this point
I fixed mine today using the soldering trick. I updated my blog post today with the pictures. Read it if you need any help for what you're looking for.
Promise Land is offline   Reply With Quote
