Old 09-19-2014, 04:33 AM   #1
aga
aga's Avatar
aga is an unknown quantity at this point
electric water pump
yo. has anybody done a conversion to el. water pump on an SR? just making discussion , after i saw this. it's meant for 3-4litre engines and more so it should be more than enough for the SR
http://www.daviescraig.com.au/
My Build
aga is offline   Reply With Quote
Old 09-20-2014, 08:41 PM   #2
zurud
zurud is an unknown quantity at this point
You need to make adapter for them. Good luck. You probably the only one thinking and using it on sr
zurud is offline   Reply With Quote
Old 09-20-2014, 10:39 PM   #3
Kingtal0n
Kingtal0n's Avatar
lets also install solid lifters. electric fans. A rom tune ecu with chips that need to be burnt. a twin disc clutch. A 2-way differential. ebay coilovers.
Lets make the car require constant maintenance and have plenty of headaches and make it a chore to drive.
https://tinyurl.com/turbo240
