1989 Hatch (CLEAN TITLE) NO RUST, 400 HP SR20, MUST SEE!!
![]() More pictures in gallery, please use link at end of description. Hello everyone, thanks for taking the time to check out my car. If you have serious interest or any questions please PM me. Anyways, heres the story I bought this car in May of 2012 from Red Lion, PA. Bought a SR swap from a JDM import site, and went to work. As far as I know its always been garage kept and well taken care of..and I will also say this is one of the cleanest, unmolested s13's you'll find. The car was built and dynoed to have some fun on the street and track. Since I've owned the car it has not seen the track at all. Have only driven this car on nice days, no bad weather. Reason for Selling: Looking to invest into a small business Location: Huntingdon, PA 16652 Cash Price: $6500 FIRM for everything or $6000 FIRM Bring Your Own Wheels. I have put a bunch of money into this car...and the price listed is only a fraction of it....the price listed is more then FAIR!!! Trades: Will be considered. Must have clean title in hand. and a trade value of atleast $8,000. Must be a clean and reliable daily. No projects!! I plan on selling any car that is traded to me. So no b.s. please. Battery: Optimum Red top w/ Full Size Battery Case Interior: Crackless dash buddy club s13 seat rails x2 buddy club spec wide racing seats (black) x2 Ebay race bar Nrg cam lock 4 point race harnesses Nrg steering wheel and hub Tomei Short shifter knob AEM truboost AEM oil pressure gauge (not installed) AEM digital air/fuel ratio gauges In dash custom 3 gauge pod Clean carpet Hks Turbo Timer I currently only have the front half of the interior in the car. Have most of the rear interior including seats that will go with the car. Wheels: (4) 17" 4x114.3 +35 works emotions cr kai wrapped in BF goodrich eagle GT 225/50/zr17 75% front 95% rear Works Lug Nuts (red) Works Valve stem (red) Engine Swap S13 SR20DET Machine work by PRL performance ebay stainless downpipe 3" Megan racing exhaust w/ test pipe ISIS M-Spec FMIC w/ piping Tial Flange ISIS Rad w/ blue hoses and fan shroud Spec Stage 3 clutch Spec Billet Flywheel 300zx Fuel Filter Z32 MAF Godspeed oil catch can B&M Short shifter Walboro 255 740cc Tomei Injectors nistune ECU tuned by PRL performance Topped out @[email protected]+HP w/ stock intake mani Tial 50mm Q bov w/ flange Nismo fuel pressure regulator Type-A Arp main stud kit Arp head stud kit tomei metal engine ornate plate greddy oil pan isis pulley kit (blue) tomei rocker arm stoppers gt2871r (.86) less than 5000 miles Isis turbo lines Isis turbo manifold Precision internal wastegate Bc retainers Bc valves Bc Springs Bc 264/264 cams Isis Thermostat ER Spec bottom end kit includes: CP pistons 86.5mm 9.0:1 , Manly Rods, Acl Bearings Body Harness Wiring specialties PRO tucked , engine harness is also tucked NGK Iridium IX (BKR8EIX) Heat Range 8 ISIS z32 maf adapter kit and filter New OEM rocker arms Circuit sports Fuel Pressure Gauge (not installed) apexi head gasket (copper) New oem speed sensor New OEM Coils Peak Performance "Black" trans mount Isis motor mounts royal purple full synthetic oil and filter for your next oil change NO POWER STEERING NO AC Q45 brake set up Fortune auto coilovers no name rear arms One piece steel drive shaft from drive shaft shop VLSD r32 axels New tie rods Clear front bumper lights Complete set of NEW oem rocker arms super tech valve stem seals (extra set unopened) S14 throttle pulley (unopened) Pros: solid VERY CLEAN s13 , runs and will drive home, idles between 13.1-13.7 on wideband, inspected until 5/16, NO RUST!!!! Cons: Minor dings and scratches on original paint, currently have battery under glove box recommend moving to rear of car. Idle control valve needs replaced hard sudden stops may result in the car stalling out. I have receipts for everything parts, build from PRL, anything!!!. And a few videos I can sent via Email. Tons of misc. parts that I did not mention. Please message me with any questions! EightOneFour-771-ThreeNineSixOne Click the link below for my gallery. http://pho.to/9e9xT/un |
