Old 06-19-2015, 10:28 AM   #1
Relentless240
Trader Rating: (50)
Relentless240 is an unknown quantity at this point
Feedback Score: 50 reviews
Nismo Mounts, Tomei Oil Adapter, Sr20 Ecu, Center Vent
Shippin available at buyers expense + paypal fees. Unless stated.
Price reduced.......
[B]I will only TRADE for: Z32 diff cover, Vertex or Cwest Wing, S14 fender brace, S14 Cf trunk, Cf Hood w Scoop, Defi Din Gauges
kouki cf cooling panel, S14 Sr20 Vtc,
PICS SOON.....
Z32 Rear Aluminum Spindles- 65
S14 Slave Cyl, RHD Clutch line- 60
S14 (came of clip 40,000 miles)oem jdm fr Swaybar with endlinks + New Energy
sway bushings & Bracket- 60
Mazwork Sr20 Head Bolts- 125 Shipped
Condition: Been torqued down Once only. Super Clean SHape.
Nothing striped, Took close ups so u can see Better.
Nismo Engine & Transmission Mount-245 shipped
Condition: Mounted only.
Sr20 Tomei Turbo Inlet Pipe & Fatty 02 Sensor- 185
Both Basically new, Idle time use only
Sr20 Tomei Oil Block Adapter-95 shipped
Condition: Idle time use only, Basically New
Box is included if wanted please Request.
Sr20 Shifter with OEM Rubber-
Sr20 Down pipe with Flex joint- 100
Brand: Megan Racing
Years: 89-98 240sx
Condition: Basically New, Bung Welded & Wideband Ready!
Zenki Sr20 Ecu-SOLD SOLD!!
JDM s14 climate Bezel w Card Holder- 110
S14 Dust Sheilds- 7 each[/QUOTE]
[B]S14 Sr20 Oem oil sender block (No sensor)- 40 Shipped
S14 lower brace Oem brackets- 45
S14 4 LUG HUBS (REARS ONLY)=30
S14 BALLER BOLTS Fr Strut bolts- 25 shipped
Slave Cylinder Low miles- 25 shipped
FR. S14 brake calipers and lines (NO ROTORS)-40
Oem S14 Radiator panels (Don't know exact name)-20
S14 tension rods-15
S14 RHD ABS unit & abs lines- 90
S14 rhd jdm A/C High side line-10
RHD S14 air ducts (Under dash)-7 each
S14 Battery/Ground wire- 7 each
Relentless240 is offline   Reply With Quote
Old 06-19-2015, 11:53 AM   #2
LuckyRPS13
LuckyRPS13 is an unknown quantity at this point
I will do $50 shipped on the Tomei oil block via USPS flat rate box. Not trying to thread shit you but your asking a few $$$ under retail for the used part.
Do you need;
Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill
S13 Silvia J's, Q's, K's, A's Bumper grill inserts.
Male Plugs for S15 headlights
PM me if you need them.
LuckyRPS13 is offline   Reply With Quote
Old 06-24-2015, 10:20 AM   #3
Relentless240
Trader Rating: (50)
up..................
Old 06-24-2015, 07:23 PM   #4
JDMJEM
JDMJEM is an unknown quantity at this point
PICS SOON.....
S14 oem Slave Damper, Slave Cyl, RHD Clutch line- 60
sway bushings & Bracket- Best offer
Zenki Sr20 Ecu-120 shipped
JDM s14 climate Bezel w Card Holder- 115
S14 Oem PS Hardline Cooler (Aluminum, PS Res SOLD)-35
[/URL]
OEM S14 Fuel pump, Works Great. Swapped for Walbro
(Lil nicked on the bottom)-30
S14 tension rods-15
JDM s14 condensor-30
[/QUOTE]
Clear your inbox please
JDMJEM is offline   Reply With Quote
Old 06-24-2015, 07:51 PM   #5
dluevanos01
dluevanos01 is an unknown quantity at this point
are the nismo mounts for ka/sr or for ca???
IG: @te37_daniel
Build thread
dluevanos01 is offline   Reply With Quote
Old 06-25-2015, 05:49 PM   #6
Relentless240
Trader Rating: (50)
Ecu sold!!
