Old 10-08-2008, 02:47 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
initial start up after swap-HELP
EDIT 10/20/2008
starter has been replaced and car cranks now, just does not fire.
please proceed to page two for the latest on this situation.
ok so i have an s14 with an s14 sr.
i just put oil and coolant in it today with hopes of getting the thing to start up for the first time today.
so i pull the 7.5A fuse for the ecu from the engine bay fusebox.
as per heavy throttles instructions, i cranked for 20 seconds, hearing a kr kr kr kr kr kr noise, that really wasnt very pleasant. i stopped
tried again. oil light still on. i went inside, and left the key in the on position.
i may have been in the house for 20 minutes
i try again, and now i get nothing but a click noise.
this is a brand new battery, could it really be dead that quick?
did i do something wrong? i am extremely scared of this in the first place because this has been a damn two year project, and if something happened to the motor now...i may just take my own life.
please help me folks!
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 10-08-2008, 03:25 PM   #2
nrmskate
nrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enough
Mine just did the same thing.
Heres even a video of how mine was.
YouTube - KA24E Troubles
I just re-charged the battery and it starts right up.
nrmskate is offline   Reply With Quote
Old 10-08-2008, 03:55 PM   #3
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
you did charge the battery before use, right?
aNskY is offline   Reply With Quote
Old 10-08-2008, 05:05 PM   #4
devonkyle77
yes
and i just put it back on after being on the trickle charger
still just does one "click" when i try to turn it over.
Old 10-08-2008, 08:29 PM   #5
devonkyle77
so i mean this thing is charged well enough after being on the trickle charger again and i get power throughout the car, but it wont even try to crank. just a click noise
noone has anything to add?
Old 10-08-2008, 08:42 PM   #6
S14DB
AFC #1
S14DB's Avatar
Take the Battery and Starter to be tested.
Old 10-08-2008, 08:45 PM   #7
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
check your flywheel?? maybe missing teeth?? if you take off the starter you should see the flywheel.
d0pe240 is offline   Reply With Quote
Old 10-08-2008, 08:56 PM   #8
devonkyle77
i know the flywheel isnt missing teeth...
Old 10-08-2008, 08:59 PM   #9
devonkyle77
as for the starter, it couldve gone bad after the engine actually trying to crank the first 2 times?
Old 10-08-2008, 10:41 PM   #10
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
devon. I will be over sometime to look at this. the charging system/battery doesn't have enough juice to jump the relay just click it. your starter is fine. I'll put money on it. yo battery is fucked. lower harness might have some faults also
ch1873857 is offline   Reply With Quote
Old 10-08-2008, 10:55 PM   #11
gippy87
gippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-known
like suggested have the starter checked out mine did something similar when it died. It took me so long to find a replacement starter that i use to have to push it hop in and pop the clutch and always try to park on a downward hill lol. trying to pop the clutch to start it while cold was a little more difficult i had to have someone push me with my other car to get it moving fast enough, yea i know sounds stupid but it was my first swap and i really wanted to drive it
gippy87 is offline   Reply With Quote
Old 10-09-2008, 12:43 AM   #12
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Get a multimeter and check how many volts are on the battery. I had a similar issue occur with my SR and it was my battery that was low on voltage. Had about 10V I believe, but it wasn't enough to get it cranking.
duffman1278 is offline   Reply With Quote
Old 10-09-2008, 06:50 AM   #13
devonkyle77
it goes all over the place between 10 and 12.40 V
Old 10-09-2008, 08:23 AM   #14
S14DB
AFC #1
S14DB's Avatar
yeah you could have cooked it in 20 secs if it was on the way out. also could have drained the battery all the way to need a couple hours of charging.
Take them to make sure you didn't smoke them.
Old 10-09-2008, 03:15 PM   #15
devonkyle77
got a new battery. 12.70A constant
i put a wrench on the crank pulley and it turned easily, so my nightmare of it being seized has been relieved.
leads me to the starter.
i understand there is a way to test it using a wire on the positive terminal and touching somewhere on the starter? can anyone explain?
Old 10-09-2008, 03:26 PM   #16
devonkyle77
here is a picture of the starter, if that helps anyone
Old 10-09-2008, 03:31 PM   #17
nrmskate
It looks like the terminals on the starter arn't very tight.
But, I would take it off and take it to Napa or O'reillys and they will test for free.
Its not hard either. 2 bolts, a nut, and a plug.
Old 10-10-2008, 01:38 PM   #18
devonkyle77
took it to ASR today and they confirmed it was "bad"
they cant tell me more until they open it up, which should be wednesday they said.
in the meantime, is there another starter that works on s14 sr?
Old 10-10-2008, 11:38 PM   #19
ch1873857
yeah. a hill and a clutch.
you have to make sure there isn't something that fried it so it doesn't keep blowing your starters
Old 10-16-2008, 03:50 PM   #20
devonkyle77
got the starter back today, put it on and now it cranks. although the car still wont start. i noticed one of the wires for my reverse position switch is broken, that cant possibly why can it?
Old 10-16-2008, 04:09 PM   #21
aNskY
more than likely the wiring is f'ed. this is a fresh swap right?
fuel lines correct?
Old 10-16-2008, 04:17 PM   #22
devonkyle77
yeah, fresh swap.
fuel lines are correct.
i primed oil pump, and now oil light goes out as soon as it starts to crank. which i would believe should be expected.
does fuel need to be primed also?
Old 10-16-2008, 04:28 PM   #23
aNskY
fuel pump should prime as soon as the ignition is "on". you should hear it clearly
Old 10-16-2008, 04:32 PM   #24
devonkyle77
oh ok. ugh, what the hell can this be?
Old 10-16-2008, 05:01 PM   #25
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
well now that it's cranking i guess the next step would be to check for fuel and spark
remove CAS, and turn it by hand while checking to see if you're getting spark (unplugged spark plug connected to the coil)
Then do the same for the injectors
96Turbo is offline   Reply With Quote
Old 10-16-2008, 05:14 PM   #26
devonkyle77
remove cas completely or just unplug it?
Old 10-16-2008, 05:25 PM   #27
96Turbo
96Turbo's Avatar
remove completely so you can turn the shaft by hand.(while still plugged in) This tricks the ecu into thinking the engine is turning to it tells the plugs and injectors to fire
edit: of course u should have the key on so the ecu/ignition system is powered up
Old 10-20-2008, 05:11 PM   #28
devonkyle77
ok not getting spark.....
Old 10-20-2008, 05:14 PM   #29
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
when my ca18 had starting issues...it was because of a bad battery ground check that
jorge1190 is offline   Reply With Quote
Old 10-20-2008, 06:14 PM   #30
96Turbo
96Turbo's Avatar
just to make sure...you were grounding the body of the spark plug right?? (aligator clip from the washer on the plug to the head somewhere)
I had a similar problem when i swapped my RB. It turned out i didn't connect a wire that powers the ignition system. It wasn't on the ECU pinout so i missed it. Are you sure you're wiring is good?
Did you check fuel? Otherwise the ECU might not be getting power or somethin
