Old 04-11-2018, 07:57 AM   #1
jslamm01
jslamm01 is an unknown quantity at this point
Found chunk of metal in the trans
So I just picked up a running 95 240 manual, the guy said it wouldn't go into first but all the other gears work fine so we drained the trans fluid was clean and no flakes but happen to see this chunk sitting by the drain plug and it wasn't magnetic so we assume it was aluminum and may possibly part of the first gear fork ? My buddy has couple of blown manuals at his house I was planning on swapping out the good parts on the s13 trans to my s14 trans but I fear that with me disassembling my current trans something else is gonna break or it won't work correctly after its reassembled, so I was wondering if it would be okay to drive it from 2nd to 5th without having a issue until I can find a new trans to swap it for. I just don't want something to dislodge and there goes the trans. The way it looks it seems like its the back of the fork where the bar slides in so Im thinking the fork can't go anywhere so I should be good, but I want to see what you guys think.
jslamm01 is offline   Reply With Quote
Old 04-13-2018, 08:08 AM   #2
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
I would get a new transmission before driving the car. You don't want to end up stuck somewhere or possibly get hurt if it locks up. Ka transmissions are cheap.
apex128 is offline   Reply With Quote
Old 04-13-2018, 08:48 AM   #3
jedi03
you will trash your clutch fast...my first car was 85 mr2, blown head gasket and transmission stuck in 3rd...super fun to drive only lasted a month and just found rebuilt engine/trans at junkyard to swap in...better to swap before you don't have time to do it...the exterior casings come off without affecting the rest of the drivetrain too
Old 04-13-2018, 09:51 AM   #4
Kingtal0n
Kingtal0n's Avatar
If second works, it uses the same fork as first. When you push forward into 1st, it pulls the fork back into 1st which is up against the center of the transmission.
Does it go first with the engine off? There are a couple small elements I can think of that would make it difficult to engage while rotating if they are missing.
Old 04-15-2018, 12:39 PM   #5
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
The shift forks are about the only aluminum pieces in the trans
and you cant swap parts from an s13 trans to an s14 unless its like a 93 trans cause I don't think manual was offered in 94 and 93+ was different than 89-92
The Game
you lose haha
kyral is offline   Reply With Quote
