Group Buys Dedicated Forum for Group Buys. |
![]() Join Date: May 2004
Kognition meter panels S13, S14
This is the first of a 2 part summer GB. This is an open GB which means there is no minimum. We are the manufacturer. End date is July 29th!
Our meter panels are designed to hold multiple instruments and maintain structural integrity in high temp and high vibration environments. We have customers around the world using these panels. Constructed from 1/4" aluminum honeycomb core, bonded with vacuum infused fiberglass panels on both sides. The top panel features a dry carbon fiber finish in 2X2 twill. S13: Requires silicone application underneath panel, it is tapered and fits flush mount. S14: Drops in with no hardware. Models available: S13/ Blank / $35 shipped inside the USA S13/ 2 hole / $45 shipped inside the USA *Outside the USA add $5.00 S14/ Blank / $55 shipped inside the USA S14/ 3, 4, 5, 6 hole / $65 shipped inside the USA *Outside the USA add $5.00 Special cuts: $10 ea. Things like AVC-R and Defi Link controller we can do. If you have something unique, we need exact dimensions. But we will do our best to cut what you need. We accept Paypal, our address is <[email protected]> (619)961-8945 for technical questions on cuts. <BR> |
Wow, nice worksmanship and fair prices. I wish I hadn't just shelled out $40 for a new OEM S14 radio trim piece, I could have paid a bit more and gotten one of these and had a place to mount gauges, to boot.
#4 | |
Thank you. You can always purchase thru our authorized U.S. dealer in the future. Panda Garage dot com.
Admin Asshole
![]() Join Date: Mar 2002
Third picture down on the right is the panel installed in an S14 dash. As well as the bottom picture on the left.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
do we need to put in the paypal msg that we're from zilvia to recieve the special price?....lmk b/c I'm gonna order one today...oh and could you clarify on the silicone "thing" for the s13 panel?..I can't believe these prices!!!!
is it possible to fit 5 60mm gauges, 1 52mm gauge, and defi link, also blitz turbo timer (about .75"x3" not exactly sure just a rough estimate) in there??? if so, how much would it cost me?
FOR S14 |
#10 | |
Yes, make a note that this is for the Zilvia Group Buy. While the panel fits flush, putting a bead of silicone around the outer perimeter on the backside gives it the monkey grip to stay in. Comes with instructions as well.
#11 | |
No, if 60mm gauges are involved, you can only fit 5 total on this panel and nothing more. Three across on the top, and two below that. Or three across on the top, and your defi link and turbo timer below that. Because of the size of the panel relative to a 60mm gauge, there isn't much room for structural material to exist between each meter hole. Price: Hole cut panel is $65, and two custom cuts are $20 = $85 shipped US or $90 shipped out of country.
#12 | |
#13 | |
I get that alot. Thanks.
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
What is GB 2. Also these look like they are clear coated or something mine is just dry carbon from Rare Trick Im still after the S-14 sunroof delete.
Slide Happy |
#15 | |
You bought an early generation of our dry carbon panels, which had a kind of rough dry finish. Our new panels are made using a new process that gives it a clean hard finished surface that is not prone to scratches. It is the true dry carbon finish like that on the HKS dry carbon Evo.
*Rare Trick is no longer a dealer for our parts. Just an fyi. Group Buy 2: Interior parts for the S14 guys, and one or two interior parts, and exterior B Pillars for the S13 guys Quote:
you wont be abel to make 3 60mm across the top, and 2 60mm on the bottom towards the side and 52mm in the middle?
and also if i have 5 gauges already, did you mean thats all i can get? i will not be abel to fit defi link unit on the bottom? let me know, i'm interested in 2 sets |
#17 | |
The Defi unit would be positioned in a bend area of the panel, but i think we can do that.
RE: Meters It would be a tight squeeze, and because of that, we would need to add an extra 2 layers of glass to compensate for surface area loss, but it can be done yes. You are really scrunching parts together though with 60mm. gauges. We will need some diameter numbers from you to make sure the gauges wont bump against eachother when seated. Quote:
#18 | |
basicly i have 5 defi bf 60mm gauges and plus one AEM uego wideband gauge.... i dont know if you guys have the reading on that... but i can find in couple days... also do u guys happen to have any pictures of finish product with 5 defi gauges on them.... |
#19 | |
We really don't have a full set of meters in the shop right now to show how it would look, but i don't think it would be to hard to envision what it would look like. We are perfectionists here so if it can be done, we will make it look good.
I suggest anyone considering this buy to take advantage of our cutting services. These panels are not that simple to cut yourself without the correct tools. And unless you make a paper template done correctly in a program like photoshop etc, to trace out your holes etc, misallignment is highly likely. Quote:
#20 |
![]() Join Date: May 2002
would u be able to do this:
1 cutout for a 60mm defi gauge (one guage) 1 cut out for the defi control box 1 cut out for a profec B greddy boost controller? i can send u a pic of how i want it arranged. it would be for a s14 also i have to see if u can do me a special project. ill pm you. lmk thanks. |
#21 | |
Sure, just pm the dimensions for it.
#22 |
UPDATE: We will make available in G.B. part 2 next month, S13 and S14 gauge panels, which will fit into your gauge for mounting your meters and Tach. Same honeycomb core and dry carbon finish. Thank Dousan for passing that suggestion on.
#23 |
well id love to see pics of those gauge panels that u have coming shortly. also, would there be any way for you to cut that piece for a normal din radio and an safc and a greddy MSS (is no bigger than a profec spec 2)? if not, what about just a normal din radio (in factory location) and an safc? this is for an s13 btw...........thanks in advance.
#24 | |
We really need dimensions before we can answer your question. But if it fits under the radio, we can likely do the cuts.
RE:Gauge panel. We are working on that this week among other things. Quote:
#28 |
Okay, this open G.B. has concluded.
We thank you for the interest and those of you who purchased. Now, as a heads up for G.B. part 2 in August, mostly player parts. Interior S14 trim kit which consists of A/C Bezel, Radio Bezel with ashtray cover, shifter trim (auto or manual), and our highly regarded armrest cover. So this is a 5 piece set, and will run about $250. The fabric orientation is the same for each part in this kit. S13, Outside B Pillars in carbon , armrest cover, and i am working on a cup holder drop in. This will take place mid august. |
#29 | |
